05-31-2019, 02:08 PM | #1 |
Rep 28
F30 M-Steering Wheel Color Restore
I found my steering wheel become very sticky so cleaned it last month, after that I found the color was gone (First and last pics). Some people said it was because the Mr.Cleaner eraser, but whatever, the point is I need to fix it.
It is pretty simple and only cost me around 40 dollar and takes around 2 hours, rescue my faded steering wheel back to new. (Pics in the middle)(I don't know how to edit the order of the pics plz tell me) What I used: 1. Leather dye (code 0523) from Leather World Technology, 2. 800 grit sand paper, 3. A good leather cleaner, 4. Several pieces of sponge The only trick is to make the color smooth and average, you probably need to apply the dye for 2-3 times, and the best way for me is to stamp the color with the sponge. Like apply the dye on the sponge first, then tap the sponge on the steering wheel and squeeze the sponge gentle. I have tried different methods including use the paint brushes and the sponge is the best tool to apply the color. A good spray gun could work but you need to cover the center console which makes it not that easy to do it at home, and I don't want to ruin my red interior with the black dye. The sandpaper I used to polish the steering wheel after the dye is dry is the Carbide Silicone base which can be found on Amazon, 800 grit works for me but I guess 600 should work as well. Last edited by sshao; 05-31-2019 at 02:39 PM.. |
06-07-2019, 05:00 PM | #3 |
Rep 16,054
Before applying dye clean the wheel with acetone, to remove dirt and oils, and especially the leather conditioner that's already there. This allows the dye to penetrate the leather, for a uniform color. After dyeing this will give a like new sheen, and preserve the finish and color:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I use this brand of dye: https://www.amazon.com/gp/product/B0...TF8&th=1&psc=1 |
Chriske9236.00 |
06-10-2019, 10:40 PM | #4 |
Rep 106
Nice work!!!!!!. And Thank you for sharing.
My steering wheel has 2 little spots on it where the color is lighter. Does the dye match the stock color of the wheel? Could I spot dye? Or do I need to commit and do the whole wheel like you did? |
06-13-2019, 02:21 PM | #5 |
Rep 28
The dye I used has the same color as the original steering wheel.
07-11-2019, 09:06 AM | #6 |
Rep 33
Hey, could you post a link to the dye you got from the website? I browsed it came across a couple of packages and really only want to buy what I need.
Do you keep applying dye until the color is completely restored or are you polishing it in between coatings? ...love your wheel btw, mine looks 10x worse than yours and ive been wondering how to fix it. |
07-12-2019, 12:00 AM | #7 |
Rep 129
Interesting DIY. My steering wheel is suffering from the same problem, will try to do this method how you did.
One question did you sponged the whole steering wheel or just the parts where it was faded? Greets |
07-12-2019, 12:16 PM | #9 |
Rep 28
I did it to the whole steering wheel as mine faded pretty bad everywhere. I assume that it is better to apply dye uniformly as there still is a very tiny color difference.
07-12-2019, 12:21 PM | #10 | |
Rep 28
07-15-2019, 05:52 AM | #11 |
No 55mph
1619
Rep 8,476
I have always used Colourlock Leather Dye, made in Germany & formulated to match BMW colors exactly
https://www.amazon.com/Colourlock-Le...ay&sr=8-6&th=1
07-20-2019, 03:14 PM | #12 | |
Rep 33
07-20-2019, 10:43 PM | #13 | ||
Rep 28
07-22-2019, 06:37 PM | #14 |
Rep 33
Gotcha. I ordered all the supplies and I should have them Thursday. Ill post pics of how it goes.
07-24-2019, 08:14 PM | #16 | |
Rep 33
I should have took before picture I started everything but I was so excited I just dove head first into it. I can say after applying the acetone my heart kinda of dropped cause the wheel lost a little color. But im on my 3rd and final coat of dye on the wheel. Once it dries Im going to polish it off. Ill post pics of the finished product. The conditioning cream comes friday. Im gonna take it real easy on my wheel until then. |
03-12-2020, 11:48 AM | #17 | |
Rep 31
08-03-2021, 11:40 AM | #18 |
Rep 425
as in Nail Polish remover as first step?
2013 328i M Sport, Estoril Blue, Venetian Beige, Walnut trim, 8AT, Premium, Cold Weather, Lighting, Technology, Navigation, Driver Assistance, HK Sound
08-10-2021, 06:41 AM | #20 | ||||
Rep 5
08-27-2021, 08:41 AM | #22 | ||||
Rep 9
https://share.icloud.com/photos/0CaS...0_SI6Dlmazw7pA |
