06-06-2023, 02:02 PM | #1 |
Rep 37
Please help! Engine failure after getting work done
Hi All,
I have a 2014 428i xDrive which has about 60k miles on it. I've been pretty much in constant fear of the timing chain guide issue on the N20 motor so I finally brought my car into an indy to check it out because I was hearing some noise I didnt recognize. Turned out the timing chain was fine but I needed to replace the oil filter housing gasket (which was already replaced a couple years ago!), serpentine belt and the e-brake cable guide clip. Apparently the e-brake cliip was most likely the noise I was hearing. I didn't go with shop which did the initial evaluation due to pricing and went to a nearby European car specialist which quoted me a much more reasonable price. The day after getting my car back my car just died while going highway speeds and I had to ghost ride to the shoulder. I had it towed back to the shop and they re-checked all their work, replaced the battery and checked the alternator. They weren't able to diagnose what the issue was but they couldnt get the engine to turn over. As a last ditch effort I took it to my local BMW dealership and paid them to do a multi-point inspection. They stated pretty much the same thing, they couldnt identify the issue. The did note a burning smell while draining the oil but I they didnt mention any issues with the gasket or anything that had been worked on. There were no fault codes or check engine lights at all prior and after the failure. The only error that popped up on the screen was an ignition/starter failure. Pretty much SOL at this point it seems but does anyone have any idea of what migh t have happened and if the work done at either shop is at fault? I don't want to point fingers but the car only had 60k miles on it and I NEVER had any major issues. The only time I got a check engine light in 9 years of ownership was due to spark plugs needing to be replaced a year or two ago. Porbably drove about 8k miles since then. I don't want to blame anyone but it can't be a coincidence that my engine simply fails days after getting work done right?! |
06-06-2023, 02:44 PM | #2 |
Rep 416
How far did you drive since getting the car back? Did you check oil & coolant levels after the repair and after the engine failed? Did any lights come on?
A seized engine with a burnt smell combined with the Oil Filter Housing Gasket job is suspicious and makes me think of low coolant or oil, but your instrument panel would light up. Unless they ran the engine with low oil or coolant during the repair, overheated and/or seized, and did a quick ghetto fix before you picked it up. If the specialist messed up by not filling oil or coolant after the OFHG job, it is likely that they got rid of any evidence by now. |
06-06-2023, 02:47 PM | #3 | |
Rep 37
06-06-2023, 03:17 PM | #4 |
Rep 7,622
Did they try turning if over by hand?
If they didnt prime the oil system after OFHG, bearings might be gone and engine seized. It's probably the most common cause of bearing failure, aside from oil starvation. |
06-06-2023, 03:19 PM | #5 | |
Rep 37
Edit I'm leaning towards it wasn't oil starvation I also requested he change the oil and he stated he used liquimoly on my vehicle. I'll have to ask him about the priming but at this point he has no reason to fess up to a mistake if it was him....sigh all this after fairly routine maintenance. Now I'm down huge with these repairs |
06-06-2023, 04:44 PM | #6 | |
Rep 7,622
If the oil is still in the car now, you would probably be able to tell from inspecting the oil filter and/or oil if it is indeed bearings, otherwise you are pulling the pan and starting to open the engine. Choose the next steps carefully if you are going to try and prove any fault. |
eluded3068.50 |
06-06-2023, 04:45 PM | #7 | |
Rep 37
06-06-2023, 04:57 PM | #8 |
Rep 63
I noticed you’re from NJ. Maybe try giving Bimmer Hub a call (google Bimmer Hub LLC). They’re my go-to local shop in Westfield, NJ and they’re extremely reliable. Owner’s name is Joe. Best of luck!
06-06-2023, 10:13 PM | #9 |
Rep 37
06-06-2023, 10:27 PM | #10 |
Insta~ f10_sapphire
158
Rep 412
They didn't prime it. A lot of shops say they have done OFHG multiple times and say they haven't had to prime it based on their past repairs. But I assure you that it's required and the cause of failure.
You should go and ask if he can go through all the steps involved with the repair. I'm sure he won't mention priming it. If he does ask him how that's done. If he gives any other method than the OEM priming procedure, you may have a case against him. But really he needs to own up to it and fix your car for free.
Insta ~ f10_shapphire
06-06-2023, 10:32 PM | #11 | |
Rep 37
06-06-2023, 11:40 PM | #12 |
Rep 215
You can choose to look at this as a positive opportunity to express yourself. You are not placing any blame, but just affirming your right to a good job for a fair price. I suggest that you bring a friend (a lawyer would be ideal but not a must) with you when you speak with the "European car specialist." You might also speak with the first "indy" who checked your car. You are not being confrontational but just getting information. You have several tools to use if necessary, including social media, local news outlets and outright law suits, but I hope none of those are needed. Just be sure to document Everything related to this incident. Best of Luck to you.
06-07-2023, 02:04 AM | #13 | |
2JZ-GTE
3069
Rep 4,015
Wow this forum and its knowledge always amazes me |
06-08-2023, 11:14 AM | #14 | |
Rep 37
06-08-2023, 11:55 AM | #15 | |
Rep 63
undertaker63.50 |
06-08-2023, 11:57 AM | #16 | |
Insta~ f10_sapphire
158
Rep 412
06-08-2023, 12:57 PM | #17 |
Rep 290
Drives: E46 M3 & LCI X3 35i M Sport
Man it's so upsetting to hear that in 2023 we are STILL not priming after a OFHG repair.
What is going on at these shops? That's awful I would be furious. Good luck to you. |
06-08-2023, 01:22 PM | #18 | |
Rep 215
