08-20-2021, 03:59 PM | #67 | |
Rep 208
Not sure if that's just because I came from pre lci and they arent bright |
08-21-2021, 02:02 AM | #68 | |
Rep 334
but to answer your questions, you need to take off a lot of the trims on the hatch ...thats the hardest part IMO...dont give up..it just takes time |
09-10-2021, 12:21 PM | #69 |
Rep 208
Hey guys, how did you do the writing from the outer tail light to the inner, I ran through and up into the boot hinge, but noticed the other day that the wire is getting caught in the spring which may cause a problem after a while of opening and closing?
09-12-2021, 02:13 PM | #70 |
Rep 383
it should not be caught in the spring run it around it and there if not wrap it in electrical tape
09-16-2021, 12:44 PM | #72 |
Rep 208
Isn't much grief fitting them tbh and prefer doing it myself as enjoy it, just wondered how people wired it as the wire has to have slack to move with the boot hinge then naturally tends to move into the spring
09-16-2021, 01:25 PM | #73 |
Rep 592
Tape the cable around the arm as low as possible to the opposite side of the spring then leave plenty of slack so any movement with the boot lid doesn't put tension or stress on the wiring.
09-16-2021, 03:31 PM | #74 | |
Rep 208
The spring, must have an awkward wire🙄 |
02-23-2023, 11:25 AM | #75 |
Rep 223
Installed these on my lci f32 last night. I can not for the life of me get the inner lights to be flush with the outers. All clips are engaged properly (I think) also, the startup sequence doesn't work on the outer lights.
Any advice? View post on imgur.com |
12-04-2023, 05:56 AM | #77 |
Rep 332
Had one of my inner lights stop working ended up buying a new set just to replace it. Strange that it’s only the reversing lights makes me think a possible wiring issues, but just guessing.
12-06-2023, 03:20 PM | #79 | |
Rep 453
Example: https://i.ebayimg.com/images/g/0aYAA...rj/s-l1600.jpg What about the individual lights on outers? - Break, turn, park? - Working correctly and only the start-up sequence does not work?
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
12-06-2023, 04:52 PM | #80 |
Rep 332
Well I would guess that the cheaper leds used have just given out. It’s not like you can even open them to check. Really weird that both have given up at the same time.
