09-13-2021, 06:47 AM | #23 |
Rep 475
I’m guessing as I found out they (main dealers) are very good at dodging any responsibility when their team mess up or outright lie to a customer. Makes you want to change brands |
09-13-2021, 07:54 AM | #25 |
Rep 1,158
09-14-2021, 02:00 PM | #29 |
Rep 1,141
They sent me a (low res) still image from the workshop CCTV footage that shows the brake fluid change machine hooked up to the car. You can also see the mechanic reaching up behind the offside front wheel.
From that at least, it appears he did go through the motions. I still need to see the full video to see if he did anything with the front outer nipples or anything at the rear. I've also sent them my photos, but not yet heard anything more. Apparently the mechanic is away on some BMW training course, and they wanted to speak to him when he was back. I'll update when I have more news. |
09-17-2021, 06:26 PM | #30 |
Rep 1,141
Had another chat with the dealer today, and also spoke to one of the technicians.
He reckons that it’s not necessary to bleed the front callipers through both nipples. He gave me some story about the fluid flowing in a loop between the inner and outer part of the caliper, so bleeding through one nipple will effectively flush both sides. You only need to use both nipples if there’s air in the system like when a new caliper is fitted. Now I’m no brake caliper expert, but I know how a caliper works and how it’s assembled. I certainly know that both sides of the caliper are dead ends. There’s an internal drilling at the lower end of the caliper that allows fluid to pass from the inner to the outer, but unless you open both nipples, you’ll never bleed the air out, or replace the fluid in each side of the caliper. If there was a second drilling at the top, you would not get circular flow. It would just take the shortest route (path of least resistance) and only bleed the inner side. I got the feeling the technician honestly thinks he’s correct, but he’s not. They did say I could book it back in so they can bleed the outer side, but it wasn’t clear if this was something I would have to pay for, or if there would be a free courtesy car. It would be good if HighlandPete could comment. |
09-18-2021, 01:50 AM | #33 |
Rep 512
Drives: 320i M Sport Shadow Edition
I would say both sides need doing…here’s a video that Kies Motorsports posted sometime ago and both sides of the calliper are bleed
ian332isport704.50 |
09-18-2021, 03:12 AM | #34 |
Rep 8,495
It's really simple. To do the job properly both sides of the caliper should be fully flushed.
That's why there are bleed nipples on both sides of callipers which have opposing pistons. You're right. The technician is wrong.
09-18-2021, 04:02 AM | #35 |
Rep 15,858
Agree. And as the video, correct procedure is outside First, inside Second.
09-18-2021, 04:50 AM | #37 |
Rep 271
Any reason why the rear calipers only have a inner bleed nipple when there is still a piston on each side?
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
09-18-2021, 05:54 AM | #38 |
Rep 1,162
I think this is better than when I had my last BMW. On that occasion they didn't do up one of the brake nipples. One of the rears was only finger tight. Needless to say the messages you get when the reservoir empties is pretty startling. I then re did the job properly myself.
Have to say the whole experience rather put me off BMW. |
09-18-2021, 09:44 AM | #39 |
Rep 1,141
On the rear calipers, there's space to have a fluid pathway above the pistons, but below the level of the bleed nipple. On the front, the only place for a fluid pathway at the top, would put it above the height of the bleed nipple, so you could never bleed the air out.
Mick.86uk79.50 |
09-18-2021, 06:29 PM | #40 |
Rep 810
The technician is talking out of his/her arse.
To help you with your resolution, i've saved and attached a PDF of the procedure from ISTA (the workshop manual). Both bleeders are described, outside and then inside |
ian332isport704.50 Ennoch2257.00 |
09-18-2021, 06:58 PM | #41 |
Rep 1,141
Thanks for that. I actually have ISTA on my laptop, so have already seen that.
09-18-2021, 10:17 PM | #42 | |
Rep 725
I have to say my outer nipples showed signs of spannering after my brake fluid change. Have mildly corroded since. I can totally see your reasons for being suspicious. |
09-19-2021, 02:29 AM | #43 | |
Rep 1,141
09-19-2021, 04:01 AM | #44 |
Rep 40
Personally if any dealer did that to me it would be the last time i use them ever! What if they were to damage your dashcam by interfering with it, they would just try and put the blame on you.
After all if they are doing their job right they have nothing to hide, or fear! |
