09-15-2021, 10:28 AM | #1 |
Rep 66
Steering Wheel Vibration @ 60 MPH
Somewhat of an odd issue maybe. I want to know what I should be looking at for this problem. My 435i seems to get a vibration through the steering wheel @ 60-65 MPH. The vibration is not present at speeds north or south of this range. If I accelerate from an on ramp to highway speeds, I can feel the vibration come on at 60-65 and then disappear thereafter. If something is making the wheel vibrate and its speed related, I would expect it to persist past 65 MPH and intensify. This is not the case here.
09-15-2021, 10:45 AM | #2 |
Rep 7,597
Check the obvious stuff... have wheels and tires balanced, check if you have pulsing or vibration under light braking, jack up the car and spin the wheels and try to "rock" them to check wheel bearings or loose suspension, etc.
Might also get better results in suspension, wheels, and tires sections. |
09-15-2021, 11:24 AM | #3 | |
Rep 66
Its just weird that the vibration shows up and then disappears - so I don't know if there is something about the driveline that vibrates at a certain oscillation/rotation - which happens to be at around 60-65 mph that I should be looking into. |
09-15-2021, 12:15 PM | #4 | |
Rep 7,597
