BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      05-03-2016, 08:30 AM   #243
shawnsheridan
shawnsheridan's Avatar
Originally Posted by CoolFX View Post
Thanks Shawnsheridan, I will try that later. Hope I don't brick my car software. can you still send me the link for the latest tool32? I found a thread that teaches how to reset frm with that software. This way i could try it if with E-sys doesn't work. Thanks again for your help. I will post the outcome.
PM sent.
      05-03-2016, 09:38 AM   #244
TeeAge
Drives: BMW 3er Touring
Hi, shawnsheridan.
Can you please pm the link to download tool32 Ediabas.
      05-03-2016, 09:39 AM   #245
shawnsheridan
Originally Posted by TeeAge View Post
Hi, shawnsheridan.
You cannot Send or Receive PM's yet. Send me one when you can.
      05-04-2016, 08:18 AM   #246
leDAHU
France
Drives: 330 Da Luxe Pack M
hi there i am also looking for a diag and erase default on my F31
would you please send me links for your latest tools
merci!!
      05-04-2016, 09:25 AM   #247
shawnsheridan
merci!!
You can clear fault codes with E-Sys.
If you want meaningful diagnosis including Interpretation of fault codes, you need ISTA/D (Rheingold), but I cannot help you with ISTA.
      05-04-2016, 05:17 PM   #248
CoolFX
Drives: BMW X3 2.0D XDrive F25
I don't know how to reset FRM with Tool32.
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on FRM (the ECU itself not the underlying CAFD) => Select CODE (not Code FDL).
Ok... Tryed this but got an error at the end.
"Transaktions-Report: Aktion: Codieren
FRM [72]
cdDeploy FinishedWithError
cafd_0000012f-005_009_018 NotExecutable"
I connected E-SYS, selected expert, then coding, read FA, Activated, read svt (right side of the screen),and right clicked on a folder with the name FRM on the left side of the screen and selected Code. That was it,right?
      05-04-2016, 08:20 PM   #249
shawnsheridan
FRM [72]
Is your FA Originial (Unmodified)?
Was Motor Running?
Can you code other ECU's this way besides FRM?
      05-05-2016, 09:45 AM   #250
CoolFX
Was Motor Running?
I will try with the motor running.
Can i do this with psdzdata lite? i didn´t install full psdzdata.
It´s the first time i conected my car to e-sys so i think fa is unmodified.
      05-05-2016, 09:50 AM   #251
shawnsheridan
Lite is fine.
      05-05-2016, 05:24 PM   #252
CoolFX
Lite is fine.
OK... Tryed again and this time it worked.... Probably I selected something wrong yesterday.
Code went ok but I still don't have license plate lights. Maybe it's another problem. Is there a fuse for license plate lights? I couldn't find it on the fuse diagram, but there are some fuses I couldn't figure out...
      05-05-2016, 05:25 PM   #253
shawnsheridan
Sorry, I have no idea on Fuses.
      05-22-2016, 04:42 PM   #254
White340
Drives: 2018 M3 Comp / 2022 X5 45e
Hi,
Could you send me the tool32 as well pls?
Thanks!
      05-22-2016, 04:45 PM   #255
shawnsheridan
Originally Posted by White340 View Post
Hi,
Thanks!
PM sent.
      05-22-2016, 04:45 PM   #256
White340
Wow man that was fast - thanks!
      06-20-2016, 05:04 PM   #257
Nassouh
Brazil
Drives: Bmw 328i
Hellow Shawn
Can you send me the tool32?
      06-20-2016, 05:37 PM   #258
shawnsheridan
Originally Posted by Nassouh View Post
Hellow Shawn
PM sent.
      06-20-2016, 08:28 PM   #259
Nassouh
Brazil
Drives: Bmw 328i
PM sent.
Thank you Shawn.
      06-21-2016, 06:24 AM   #260
speed608
Malawi
28
Drives: F30 320d
Hi Shawn,
Can you please send me the download link for Tool 32 please.
Thanks in Advance .
      06-21-2016, 06:27 AM   #261
shawnsheridan
Originally Posted by speed608 View Post
Hi Shawn,
Thanks in Advance .
PM sent.
      06-28-2016, 04:38 PM   #262
Nicolai-K
Denmark
Drives: F25
Hallo Shawn
Can you send me link for tool32?
Thanks!
      06-28-2016, 04:51 PM   #263
shawnsheridan
Originally Posted by Nicolai-K View Post
Hallo Shawn
Thanks!
PM sent.
      06-29-2016, 10:12 PM   #264
TURBO4DR
Drives: 2012 BMW 335i
Hey Shawn if you don't mind can you send me link for Tool32 as well for clearing codes.
