BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Automatic Gearbox shocks F30 320ED 2013
      01-23-2020, 03:34 PM   #1
Dani988
Drives: BMW F36
Greetings,
I'm having an issue with my ZF8HP on my 320ED for which the root cause can't be identified by local dealer.
Please see video here:
In this video the doors are open and the sound made by shock can also be heard.
Shock occurs when stationary and switching from D or R to P. This does NOT happen while driving.
Gearbox ZF8HP has been COMPLETLY REPLACED (including oil change and gearbox values reset) with a new one by local BMW dealer but shock problem is still present.
Please share thoughts and solutions.
Thanks!
      01-24-2020, 12:44 PM   #2
RJR82
Drives: Bmw 318d
could be a bit of play somewhere in the drive shaft, one of your guibo's mabe,
when going into D its taking up slack if you know what i mean, but i would have thought they would check things like this when swapping out gearbox,
just an idea!
      01-24-2020, 01:00 PM   #3
Dani988
Drives: BMW F36
just an idea!
Thanks for your support.
Do you happen to know any youtube videos for this transmission giubo ? As I am not an expert, I am trying to provide local dealer some ideas.
Additonally, someone recommended changing the battery as this was the solution for him to solve a similar issue. Is it possible ?
      01-24-2020, 03:57 PM   #4
RJR82
Drives: Bmw 318d
a guibo is a rubber flange inbetween drive shaft connection and gearbox( also inbetween driveshaft and diff) google guibo!
also if you google or search on here , gearbox adaptation reset procedure, it might be worth a try
      01-24-2020, 04:07 PM   #5
Dani988
Drives: BMW F36
Thanks! Found it. Readaptations have been made by dealer. Do you think the battery could also be root cause ?
      01-25-2020, 05:13 AM   #6
RJR82
Drives: Bmw 318d
i cannot see the battery itself causing an issue like that, but disconnecting it for a while might reset any software gremlins you could have
      01-25-2020, 05:45 AM   #7
Dani988
Drives: BMW F36
Ok. I'm taking the car to the dealer on monday. I'll point out what you said. Hope I can solve this as this case has been open for 4 months now...
      01-28-2020, 04:11 AM   #8
Apples12
Drives: 520D LCI auto
Mine did exactly the same.
Changing engine and gearbox mounts about 100,000 miles ago helped.
The mounts have since worn and the jolt is back again, new mounts going in tomorrow
I used febi mounts if that helps
      01-28-2020, 04:15 AM   #9
Dani988
Drives: BMW F36
Hi,
My car is at the local dealer now for another investigation. Yes, I also have mounts on my purchase list. There is also a clunk noise, like metal hitting metal.
      01-28-2020, 05:22 PM   #10
Apples12
Originally Posted by Dani988 View Post
Hi,
This sounds exactly like mine.
Please update on how you get on, mine was better after mounts etc, I'll update tomorrow afternoon after I've had a new set fitted
      01-29-2020, 12:52 AM   #11
Dani988
Drives: BMW F36
Hi,
Car is still at dealer. It takes a huge amount of time in Romania to get the car fixed. I'm in the 5 month with this issue. They still don't know what's causing this. However, I ordered:
1. Engine mounts
2. Gearbox mounts
3. Flex disks for driveshaft
Trying to find the root cause.
      01-29-2020, 06:20 AM   #12
Apples12
Have you had gearbox service/oil change?
      01-29-2020, 06:27 AM   #13
Dani988
Drives: BMW F36
Yes. As dealer BMW said and also written in the invoice the gearbox (including mechatronic, convertor, egs module) and OIL have been replaced. I also saw the old replaced gearbox but they did not let me take the serial number part. I hope it is not a scam... it's an official BMW dealer, the biggest in Bucharest: Automobile Bavaria Baneasa.
      01-29-2020, 09:35 AM   #14
Apples12
Mounts changed and no difference in the jolt
I think it is more in the actual gearbox itself.
My car is at 150k and it's done it for the last 50k, it will go for gearbox service again in 10k miles I'll update then.
      01-29-2020, 09:38 AM   #15
Dani988
Drives: BMW F36
Sorry to hear that. Mine is 87k and it does this. Do you also hear a clunk under de car ? Like metal hitting metal ?
      01-29-2020, 10:53 AM   #16
Apples12
Yes, exactly the same.
Worse if going from reverse into park
It sounds like solenoids aren't being damped in my very uneducated opinion.
I will tolerate and live with it until I change the car.
      01-29-2020, 11:28 AM   #17
Dani988
Drives: BMW F36
I talked with the dealer today and they said that it can be a "bad consumer" on the electrical side... They are trying this approach now. Did you have any electrical problems or weak battery ?
      01-29-2020, 11:42 AM   #18
Apples12
This is interesting as I have had a low voltage code stored in my car's ecu which keeps coming back.. car seems.to start and drive okay so I haven't really been bothered about it.
The battery is the original one from 2013 and is 150k miles old.
I may look to get it replaced
      01-29-2020, 11:55 AM   #19
Dani988
Drives: BMW F36
Seems plausible. I had my minus battery cable (including IBS sensor) replaced because start/stop function was not working. A test with a new battery, OEM and coded/registered would help.
      02-04-2020, 01:26 AM   #20
Dani988
Drives: BMW F36
Changed battery. Same issue. A strong clunk and noise happens when pressing P button. Will change flex disk next.
      02-05-2020, 05:20 PM   #21
Apples12
Please keep us posted.
Does it only give you the clunk when your doing it parked up stationary and repeating the d>p>d>p routine?
Mine doesn't do it if I've just been driving and come to a stop.
If I then continue to cycle from drive to park it will then make the exact same clunk.
Tbh I'm not too bothered by it as it only happens when I stop... I leave auto hold on when I lock the car it engages p by itself
      02-06-2020, 10:40 AM   #22
Dani988
Drives: BMW F36
Hi,
Yes, while stading still on flat surface doing d-p, d-p, d-p. When pressing P I get huge jerk/jolt/shock (you can see it and hear it in video I posted initially).
I also check guibos/flex disks at dealer. They are ok...
After 5 months of service at BMW they can't fix it. They said something about calling someone from Germany, but that means at least 2 additional months.
Maybe the new software of the gearbox is not working ok with the ECU...
Did you check yours at a service ?
