09-16-2021, 08:16 AM | #1 |
Rep 80
What type of oil should I get next?
I used castrol 5w30 high mileage last time and wondering if I should try something new. I’m currently tuned on BM3 OTS map Stage 2H and wondering if I should go to 5w40 and if I should change to castrol oil to liquid moly, and suggestions?
2014 m sport 435i rwd fbo VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2 AGG 91 bootmod3 New ngk Cold spark plugs New oem ignition coils Vargas stage 1 upgraded turbo 89500 miles Bm3 transmission tune |
09-16-2021, 10:41 AM | #2 |
Rep 16,060
1. Ask in the correct forum: https://f30.bimmerpost.com/forums/fo...play.php?f=437
2. Be prepared to get so many 'expert' opinions that you'll consider buying stock in armchair manufacturers. |
09-16-2021, 11:58 AM | #3 |
Rep 7,597
You can read the literally thousands of posts on this exact same topic (in the section linked above), or, if you are going to skip doing your own research, if you are using vegetable oil try canola oil, or vice versa.
09-16-2021, 12:42 PM | #4 |
Rep 975
I prefer peanut oil myself. If it makes those damn Five Guys fries taste so good, can't be that bad.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
09-17-2021, 05:39 PM | #10 |
Rep 2,897
Tuners usually recommend 5w40 either Motul or Liqui Moly.
If you prefer to stay in the 5w30 weight, Motul has a BMW LL01-FE specific oil that has a sheering index almost as high as most 5w40 oils. Hope this helps |
