BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Low Coolant Level
      04-29-2019, 11:48 AM   #1
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Low Coolant Level
Hello -- just reaching 78k miles on my 2013 f30 328i (n26) and lately have received about 4 or 5 low coolant level warnings when starting my car.
Luckily, its usually when the car is cold so I turn off the engine and check the expansion tank to confirm that the coolant level is at the max line.
I've read the following posts already:
https://f30.bimmerpost.com/forums/sh...coolant+sensor
https://www.reddit.com/r/MechanicAdv...30_p143c_code/
https://www.bimmerfest.com/forums/sh...php?p=12737475
And have come to different conclusions. Some say that a new expansion tank is required. Some say that the sensor is built into the radiator and a new radiator+sensor is required. It doesn't seem that there's really ever any resolution posted anywhere.
The car appears to be operating normally. The oil temp gets up to 240ish or just under the 250 mark after sustained driving at 80mph on the freeway and quickly drops when coming to a stop.
Is it safe to continue driving and periodically checking the coolant level by eye?
Does anyone know if the sensor/radiator are needed or just the expansion tank....or all 3?
I will check tonight if I have any codes related to it.
Thank you
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
      04-30-2019, 06:10 AM   #2
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
If the coolant isn't actually low, then it's safe to drive. I'd guess you need to replace the coolant level sensor, which is integrated into the reservoir (see the plug at the bottom).
PN: 17137642158
Youtube/Instagram/TikTok: @kern417
MONSTAR517.00
      04-30-2019, 12:31 PM   #3
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
PN: 17137642158
Thanks bud! I'll order that now and keep checking the level. I'm planning a maintenance day soon with an oil change, plug change, air filter clean, etc. so I'll probably do it then.
kern4174446.50
      05-02-2019, 09:55 AM   #4
Rayzor
South Africa
Drives: F10 Msport 535i
I am having the same issue with my f30 335i, ran the bleed test and the waterpump is working as it should. I am going to try and do a coolant flush and as a last resort replace the expansion tank. If you resolve the issue, please update the thread.
      05-02-2019, 02:18 PM   #5
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Sure man, I'll keep it in mind. I think its a good opportunity for me to switch to redline water wetter and distilled water
      05-05-2019, 12:57 AM   #6
Blemus2061
Drives: Bmw f30 328i
Don't forget to make sure you don't have corrosion in the connector for coolant level sensor in the expansion tank. Sometimes leaks through connectors and corrodes the harness and needs to get replaced. There's a repair kit from bmw for that as well
      05-06-2019, 08:04 PM   #7
MacsRule
MacsRule's Avatar
Drives: 2012 335i
Thank you
For what it's worth, I got the same low coolant alerts and it ended up being the oil filter housing. The gasket failure was causing the coolant and oil to slowly leak. Make sure you check the filter housing and surrounding area before making a more costly repair.
      05-16-2019, 10:47 PM   #8
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Just wanted to update that I hadn’t pulled the trigger on ordering a replacement expansion tank yet. It’s been 2 weeks and I stopped getting the low coolant level warnings. I was checking daily before my commute to work and the level has been at the max line since this started.
It may have been caused by our fluctuating weather here in SoCal but I’m not sure. I will definitely update if the warning comes back and if I go through with diagnosing/replacing
      06-07-2023, 11:24 AM   #9
mechatony11
Drives: toyota
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently; the radiator coolant was mysteriously getting low. As I further checked the hoses, cracks in the radiator, or head gasket, there was no sign of leakage. It turned out that my radiator cap was damaged and it’s not holding the standard operating pressure anymore, so I immediately replaced it. I came across an in-depth article that may be worth reading. Search for "Mercedes-Benz Check Coolant Level Warning Light on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
