12-20-2023, 01:55 AM | #1 |
that340i
Rep 6
Hit Pothole and now car is kinda vibrating as soon as steering tilts to right.
I Drive 2016 BMW 340i xdrive. A week ago I hit Pothole and now car is kinda vibrating as soon as steering tilts to right. But goes back to normal as I straight up the steering wheel or turn it to left. It sounds like it is rubbing against something and I can feel strong vibrations in gas pedal and steering wheels. I did visual inspection and right side strut is almost touching the wheel. I’m attaching the pictures. Please help me as I already spend lot of money and shops are not able to find out the issue. Got the wheel balancing and alignment done but issue is still there.
12-21-2023, 08:21 AM | #2 |
Rep 197
From the photos, you can see the bottom of the strut was pushed through the knuckle, almost contacting the CV axle. It is a common fail point to protect the top strut hat if you do in fact hit a pothole.
I would replace the strut and knuckle, and inspect the axle as well to see if that was also compromised. I would also have the wheel checked for a flat spot or out of roundness. |
12-21-2023, 01:59 PM | #3 | |
Rep 47
If it is not these issues (strut and knuckle and possibly axle) I would suggest wheel bearings. You might have knocked the axle hard enough onto the bearing and chipped one of the grooves inside. |
