10-01-2018, 08:41 AM | #1 |
Rep 27
Help needed for winter setup
Hi guys, I have a 2018 340 iXdrive with stock adaptive M chassis. Current staggered setup for summer 225/40R19 with 8'' ET 36 front and 255/35R19 with 8.5'' ET 47 rear. Now it's time to consider winter setup. A local guy has a square winter set for sell: 255/35R19 with 8.5'' ET35 off his 2016 M4. Not sure for any issue to put on my 340, especially the front.
I know this kind of questions had been asked almost every year around this time. Did some search but most OPs had lowed their suspension and mine is stock. Appreciated for any advice given! |
10-01-2018, 10:10 AM | #2 | |
Respect My Authoritah
368
Rep 873
I found this site very helpful. I used it, this morning, to determine that a set of CL wheels would not fit my car. You need to make sure that "poke" isn't too far off and that the wheels will fit the strut. People running spacers (on 400M's) are using 18x8 ET34 with a 10mm spacer (simulating ET24) in the front. In the rear, 18x8.5 ET47 with a 15mm spacer (simulating ET32). The 1/2" rim width difference accounts for the ET difference between front and rear. You'll have to do the calculations with 19" wheels, but the calculator makes it easy. For reference, most people running 19" VMR's are using ET35 all around. I was quoted recently and they suggested to do 19x8.5 ET35 front and 19x9.5 ET40 rear. I'm not giving you a definite answer, because I don't want to be responsible for fitment issues. But.... I think the rears would fit perfectly, while the fronts would need a small spacer to be "flush".
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
10-01-2018, 11:22 AM | #3 |
Rep 16,081
You're begging for pothole damage to both tires and wheels with a 35 aspect ratio tire. Also, the wider the tire the less traction you have in snow and slush. You should be looking at 18s with 225/45.
Sportstick4652.50 |
10-01-2018, 12:12 PM | #4 | |
Rep 78
My winter set of wheels is: 8Jx18 ET34 225x45 R18 (all wheels are the same) Indicated set of wheels (255/35R19 with 8.5'' ET35) it will fit, but such a width of tires will be less secure Last edited by maku; 10-01-2018 at 12:20 PM.. |
10-01-2018, 12:43 PM | #5 |
Rep 6,028
Agree. For winter time in Canada, the question is what studless winter (not performance winter) tires can you find in the narrowest width with enough capacity to hold your car's weight. Drive carefully for the hell months and wait for Spring! Study tirerack.com for answers.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
10-01-2018, 01:21 PM | #6 |
Rep 27
Thanks guys for the reply. I also tried on WillTheyFit but it only tells how much the new setup will be closer to the strut or how much it will pock out. It won't say if it fits for any particular vehicle. I know 225/45R18 maybe the best config for winter, safety and comfort wise. Still considering between these two options. My daily commute is very short and in town and no intention to drive crazy during winter.
10-01-2018, 01:32 PM | #7 | |
Rep 6,028
othniel0.00 |
10-01-2018, 09:39 PM | #8 |
Rep 43
Drives: X5 3.5D, e46 330xi, 340xi
Have the same car. My winter setup is square 245/40/18 michelin pa4 on oem 398 wheels and I have no complaint about it. Always felt safe in all the crazzy Quebec winter conditions. Actually I prefer this setup over my summer staggered 225/255 pss. Car is more balanced. I wonder if the 340 is not to powerfull to run on 225 winter square. It might lack of grip on a daily basis unless you use the eco mode for all winter.
10-04-2018, 08:24 AM | #9 |
Rep 6,028
35 mph is 35 mph regardless of having a 4 or 6 cylinder engine, and the rate of acceleration is totally controlled by the driver, so I question the premise of being too powerful for a 225 tire. The goal in winter is to have the narrowest tire which fits and has load capacity for the car. You have done well with the PA4, as it is not Michelin's most capable winter tire, which would be the XIcexi3. Hope they continue to serve you well if/when called upon for maximum stopping power on snow/ice.
10-09-2018, 10:39 PM | #10 | ||
Rep 43
Stopping is one potentially hazardous driving condition. Breaking traction while accelerating is another one. This time torque comes into play. On slippery surfaces, the more torque the hardest to control the acceleration without breaking traction. It can rapidly become tricky when cornering. When I bought that nice Audi S4 V8, I thought it would be a blast in winter conditions over my A4. I was wrong. Was a lot easier and fun to drive and control the A4 in the snow. For the same reason, my old 2001 330xi is more fun to drive during winter snowfall than my 340xi. Best advice is fore sure to adapt your driving to road condition, keep safe distance and anticipate for the worst. |
10-10-2018, 08:15 AM | #11 | |
Rep 6,028
Again, no point to further debate here. One can read about this from a variety of credible sources rather than anonymous forum members.
10-10-2018, 10:18 PM | #12 | ||||
Rep 43
10-11-2018, 08:15 AM | #13 | |
Rep 6,028
I'll try to help with a head start: https://blog.tirerack.com/blog/hunte...ter-for-winter https://www.oponeo.co.uk/tyre-articl...res-for-winter http://www.rimsandtiresmag.com/7-thi...s-narrow-tire/ https://resources.tireamerica.com/re...el-tireamerica
10-12-2018, 10:12 PM | #14 | |||
Rep 43
Nevertheless, I invite people interested in reading scientific literature about tire to subscribe to journals like this one: http://tiresciencetechnology.org/doi...urnalCode=tist Or if you want an overview of what can be found in those kind of publication, i found this for free: https://vtechworks.lib.vt.edu/bitstr...pdf?sequence=1 |
10-14-2018, 08:02 PM | #15 |
¯\_(ツ)_/¯
945
Rep 1,762
OP, pass on those wheels. Look for 18's with as narrow tires as possible.
