02-27-2016, 06:53 AM | #23 | |
Rep 1,067
07-04-2016, 08:04 PM | #24 |
Rep 191
question, i just upgraded stock 328 calipers/rotors (312mm) to the 335i (340mm 4 piston)
do i need to add fa S2NH?
2012 335 2016 435 2019 440 GC |
02-11-2017, 08:43 AM | #25 |
Rep 597
02-11-2017, 11:24 AM | #26 |
Rep 191
no need, brakes performed great. i also noticed my rotor size was already set to 340mm when i went in to code
03-17-2017, 03:15 AM | #28 |
Rep 20
Hello guys, I own a European BMW F20 (116i, N13 engine).
I've installed the M-Sport big brake kit (front and rear). Not the M-Performance. Although from the dealer told me they have coded the car (there's only 1 coding procedure for both M-Sport and M-Performance), I feel the initial bite really bad compared to stock. What parameters should I check in ESYS if they had the coding properly?
BMW F20 (2015) 116i M-Pack
03-17-2017, 04:47 AM | #29 |
Rep 817
Drives: bmw M3 F80
03-17-2017, 05:08 AM | #30 | |
Rep 20
So I must have these lines enabled because of the dealer told me they had made the coding. I will give it a try and post back.
03-17-2017, 05:29 AM | #32 |
Rep 817
Drives: bmw M3 F80
03-17-2017, 05:31 AM | #33 |
Rep 817
Drives: bmw M3 F80
03-17-2017, 05:39 AM | #35 |
Rep 817
Drives: bmw M3 F80
03-20-2017, 01:56 PM | #36 | |
Rep 1,986
Installing 6 Cylinder Brembo GT BBK rotors and brakes. 1) What EXACTLY does the M-Performance Brake coding do? 2) Should I code for MPerformance Brakes with the superior Brembo GT? Any clarification you can give would be greatly appreciated. |
03-20-2017, 02:24 PM | #37 | |
Rep 40,745
Kabrich354.00 |
03-20-2017, 06:31 PM | #38 |
Rep 1,986
Why would size of rotor matter in the coding?
03-20-2017, 06:32 PM | #39 |
Rep 40,745
I never looked into that deep. I think answer is going to be rather technical related to DSC Parameters and the width of the rotor.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-20-2017 at 06:41 PM.. |
03-21-2017, 08:06 PM | #40 | |
Rep 1,986
Best guess an European Performance shop gave me, which makes the best guess / sense at this point is it might deal with how the ABS System works. That's only a guess, but better than anything else I have heard - or that anyone has come up with for that matter. |
03-30-2017, 10:18 AM | #41 | |
Rep 603
In the Vehicle Profile the intalled Sport Brake is listed [8] Aftermarket_Fitment [1957] SPBR_18_ZOLL_SPORTBREMSE In the DSC CAFD file. C_Variante_Bremsscheibe_vorne_e was still set to 30/340 C_Variante_Bremsscheibe_hinten_e was still set to 20/330 I FDL coded these values to 30/370 and 24/345 (installed rotors). I must admit no noticeable change in brake behaviour. Placebo effect yes, but not like day/night. In a blind comparison I doubt anyone would feel a difference. Anyhow, I often read the people installing the 18" brake kit should code above values, but I never saw that coding of C_Variante_Bremssattel_vorne_e C_Variante_Bremssattel_hinten_e also should be changed to the "right" values. (They where set to the right values in my car 4-piston front/2-piston rear, although the rotor values where not) Could it be, that changing these values has a much bigger impact, as it tells the DSC Module what calipers are installed? DSC Module will possibly adapt the brake pressure and balance also based on these values?
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
03-30-2017, 10:25 AM | #42 |
Rep 40,745
I don't know exactly, but I do know, as I wrote above, any official dealer install will be VO Coding only, and no additional FDL Coding.
03-31-2017, 12:30 PM | #43 | ||
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
It made a very nice difference in pedal feel. Mush was eliminated and it is super nice now throughout the travel range of the pedal. I also noticed under DSC it remained the factory setting of 340mm/330mm and coded to appropriate bigger disc sizes and FWIW I didn't notice any difference. All this thanks to shawnsheridan super helpful and provided awesome step by step directions.
FBO-PS1 and stuff
04-02-2017, 03:44 AM | #44 | |
Rep 603
C_Variante_Bremsscheibe_vorne_e C_Variante_Bremsattel_vorne_e C_Variante_Bremsscheibe_hinten_e C_Variante_Bremsattel_hinten_e to the lowest possible like a 316i brake setup. Took a drive around the block and didn't notice any difference. (Then recoded the FDL to the right M Performance values.) Didn't have much time to spend, just my quick impression. I assume probably VO coding changes a bunch of values. I also don't know, what exactly will change. (Initial brake pressure, emergency brake pressure, behaving of ABS/DSC, front rear brake balance....) I would be interested to know.
