04-05-2014, 07:03 AM | #1 |
Rep 97
Sport Mode
I've got a March 2014 330d M Sport without Active Suspension or VSS.
On my car, I presume that in SPORT or SPORT+ modes, the steering and suspension are not adjusted in any way? On my car, would there be any difference from moving the gear selector left or selecting SPORT mode with the driving experience switch? (Apart from being able to use manual shift of course). I've only done a few hundred miles so I don't know the car well enough to notice any difference. |
04-05-2014, 08:02 AM | #5 |
Rep 97
Thanks for the replies, I know the following (I think) about SPORT mode:
The throttle response is more sensitive and the gearbox shift points are raised. The gearbox will not select 8th gear (in A/T) And I believe that SPORT+ mode (in addition to SPORT): Changes Stability control from DSC to DTC Disables kick down and upshift (even at the red line) What I don't know is what I asked in my original questions |
04-05-2014, 08:06 AM | #7 | |
Rep 270
Drives: 335D Min Grey Beige Reg 3/2014
My options are in the idrive options, select either both sport in drivetrain and chassis or one of these as required. In my case the drivetrain shows much more urgency than in comfort mode if drivetrain is selected. Others may have experience of the sports chassis selection as opposed to,default "comfort" mode. |
04-05-2014, 08:07 AM | #8 | |
Rep 20,651
Ok then no, apart from answers above, no difference. Biggest change is sport + due to traction. |
04-05-2014, 08:12 AM | #9 |
Rep 2,511
A 330d has Servotronic Steering as standard. So, the steering will also 'weight up' in sport mode (if chassis is selected?).
The rpm's sit at 2k, ready for action. Usually 1,100 up in comfort. The throttle becomes more sensitive and it just wants to shift!
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
04-05-2014, 08:41 AM | #10 | |
Rep 15,858
Using sport mode with drivetrain checked typically drops one gear, additionally flicking the stick to M/S will often drop another gear depending on road speed, (two if you go the M/S in comfort mode) as the sport mode does not set the gearbox change points quite the same or as aggressively. I've described the gearbox sport mode as a "half-way function", in my 5-series. 7th & 8th gears do engage in sport mode, or M/S program, but requires roads speeds way above legal speeds to see 8th gear. HighlandPete |
04-05-2014, 10:26 AM | #12 | |
Rep 2,511
04-06-2014, 02:50 AM | #15 |
Rep 125
I think steering gets more aggressive (read: heavier) when you enter Sport if you have servotronic. Unfortunately, I can't go out and test this for you as I'm in the middle of the worlds longest 8 weeks. Ever.
04-06-2014, 02:55 AM | #16 |
Rep 20,651
Try putting an order in beginning of February for June delivery ! Lol
04-06-2014, 03:26 AM | #17 | |
Rep 1,239
The wait's a killer though isn't it.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
04-06-2014, 03:32 AM | #18 | |
Rep 626
04-08-2014, 03:43 AM | #19 | |
Rep 97
04-09-2014, 11:11 AM | #20 |
Rep 270
As far as I 'm aware the fact that I do have Adaptive Msport suspension doesn't affect the option to configure sports mode.
It it's possible the sequence in IDRIVE is Select SETTINGS Select DRIVING MODE SElect CONFIGURE SPORT check one of three boxes Drivetrain/chassis Drivetrain only Chassis only Hope this helps. Drivetrain certainly livens up response in my one month old 3 series. |
04-09-2014, 01:38 PM | #21 | |
Rep 626
04-09-2014, 02:19 PM | #22 |
Rep 270
