08-12-2019, 12:37 AM | #1 |
Rep 11
Need help coding Mperformance brakes
HI, I'm very new to bmw`s and coding. I just installed Mperformance Brakes on my 2013 335i and bleed them and pedal still feels mushy to me. Can anyone help me code for the brakes and upgraded rotor size?? I'm Located in Socal. San Gabriel area. Will definitely appreciate aND pay for someone's help and time.....
08-12-2019, 12:47 PM | #2 | |
Rep 40
08-13-2019, 07:24 AM | #4 |
Rep 11
08-13-2019, 01:28 PM | #5 |
Rep 145
08-14-2019, 01:16 PM | #6 |
Rep 40
08-20-2019, 11:10 PM | #9 | |
Rep 5,392
Often coding isn't necessary depending on what the stock brakes were before and how their front to rear bias is already programmed. For instance I've been told by several BMW trained techs that no coding is needed if upgrading from F30 335 stock brakes (4-piston front 340 rotors/1-piston rear 330 rotors) to M-Sport or M-Performance brakes that use 4-piston front 370 rotors/ 2-piston rear 345 rotors. |
08-22-2019, 10:17 PM | #10 |
Rep 425
I did not get mines coded. I had the stock grey brembo's on my f32 435i. Upgrade to the mp brake kit and not problems at all. I did use a power bleeder and rebled the system after about 100miles just to be safe/perfect.
08-30-2019, 12:42 PM | #11 |
Rep 14,115
Drives: G82 M4C X-Drive
Sounds like you still have air in the system.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
