11-14-2018, 05:09 AM | #1 |
Rep 560
LED vs xenon lights
So after driving the LCI 330 for a while with LED they feel whiter and maybe brighter ?
My pre LCI 330 has xenon light and I'm feeling the love for LED now I have read loads of here that people like the xenon lights more than LED why is this, is there a negative to LED |
11-14-2018, 05:22 AM | #2 |
Rep 326
My opinion is that the LEDs are often set up incorrectly from new
When I first took my LCI car out at night it was just plain dangerous, however tweaking the beam pattern helped enormously I suspect lots of the LED hate is due to this |
11-14-2018, 05:54 AM | #3 |
Rep 1,801
Xenon's have more light output than LED's.
Adaptive LEDs have more light output Standard LEDs. LED's are whiter so they appear brighter. Last edited by chris-c; 11-14-2018 at 07:00 AM.. |
11-14-2018, 06:06 AM | #4 |
Rep 8,081
An individual xenon lamp has more specific output per source but then on LEDs you have twice the number of elements (both inner and outer lights are used each side) so overall LEDs have a slightly higher output in terms of lumens. There is no difference between adaptive and non-adaptive though as they use the same elements.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-14-2018, 06:39 AM | #6 | |
Rep 215
It's critical you take time to set your LEDs correctly. |
11-14-2018, 06:40 AM | #7 | |
Rep 215
11-14-2018, 06:43 AM | #8 |
Rep 8,081
Ian
11-14-2018, 06:51 AM | #9 |
Rep 8,636
LED on the M140, Xenon on the F31 prior and F30 post.
I prefer Xenon |
goodbyalfa1056.00 |
11-14-2018, 06:55 AM | #11 | |
Rep 6,944
Thankfully Laserlight is coming to the new 3/4 and (presumably LCI 5). That appears to be a real step up from xenon. |
11-14-2018, 07:00 AM | #12 | |
Rep 1,801
Low Beam: F30/31 LCI Standard LED: 784 lm F30/31 LCI Adaptive LED: 1097 lm F32 Xenon: 1170 lm F32 Adaptive LED: 903 lm High Beam: F30/31 LCI Standard LED: 1226 lm F30/31 LCI Adaptive LED: 1498 lm F32 Xenon: 1702 lm F32 Adaptive LED: 1802 lm Total F30/31 LCI Standard LED: 2010 lm F30/31 LCI Adaptive LED: 2595 lm F32 Xenon: 2872 lm F32 Adaptive LED: 2705lm |
11-14-2018, 07:06 AM | #13 |
Rep 8,081
Those figures are wrong. For a start the "Total" makes no sense in the xenon application because the lamps are bi-xenon and do not operate clumatively. The output on high beam is the output of the element with the shutter dropped, it's not "added" to the low beam output.
Ian
11-14-2018, 07:29 AM | #14 | |
Rep 1,303
Which i am glad for.... hated headlight washers on every car i owned.... didnt clean the headlights and just dirtied the bonnet/ got frozen or jammed in winter. |
goodbyalfa1056.00 |
11-14-2018, 08:21 AM | #16 |
Rep 1,894
I'm yet to try my car in the dark! I had adaptive xenon's on the F31, which I really liked. Will be interesting to see how they compare to the G31 Icon lights.
11-14-2018, 08:34 AM | #17 |
Rep 926
11-14-2018, 09:32 AM | #18 | ||
Rep 2,511
However, living in the country and driving muddy winters roads at night makes both adaptive and head light washers very useful. My pre-LCI standard Adaptive Xenon washers were much more active than the LCI option Adaptive LED washers on my present car. For starters they triggered on every first wash after the headlights came on. I'd estimate that they are used less than 25% of the times they were with Xenons. During periods of poor weather I wash my screen multiple times to force a headlight wash. I wonder if the lack of a legal requirement for washers on LED's makes for dirty lights and so relatively poor performance. Dirty headlights do make for a big difference.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
11-14-2018, 09:52 AM | #19 | |
Rep 431
When I first drove with standard LED's thought they were terrible, no distance to them. Had ACS springs fitted, headlamp adjustment is recommended I believe. The distance vision improved greatly, but I kept getting flashed. Took it to BMW to adjust and they are great now, greater distance vision and no flashing. |
11-14-2018, 11:55 AM | #21 | |||
Rep 19,982
11-14-2018, 01:29 PM | #22 | |
Rep 1,446
I also prefer the xenon lights. As noted above, the LEDs produce a whiter looking light but I prefer the more 'natural daylight' tone of the xenons and I think the light dispersion (if that's the correct term) is better. Aesthetically I also think the xenons look better when lit, although in the F30 I preferred the angel eyes on the LED cars.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
