07-18-2019, 01:03 PM | #1 |
¯\_(ツ)_/¯
945
Rep 1,762
DIY: Performance Side Skirt Extensions Install
Hey guys, here's a quick vid I made for installing the side skirt extensions on your 3/4/5 series.
For this application I only used 3M double sided tape (1" width) and did not install the pop rivets/screws.
07-18-2019, 03:38 PM | #2 |
Rep 1,286
07-18-2019, 03:52 PM | #3 |
¯\_(ツ)_/¯
945
Rep 1,762
Anytime. I picked them up from a forum member who took them off his F30.
Part number for them is; 51192291404 51192291407
07-18-2019, 05:28 PM | #4 |
BMW CCA Member
488
Rep 808
You may want to use the screws. Dirt and water roll right into that space between the skirts and body panels, plus you are fighting gravity. I've used the 20lb strength 3M tape and once contaminated, the stuff just falls off.
With screws, they will stay on even when the wife... ahem... steps on them.... |
AddictedTo///M217.00 _bdiddyb_215.00 |
07-18-2019, 05:30 PM | #5 | |
¯\_(ツ)_/¯
945
Rep 1,762
07-23-2019, 07:24 AM | #6 |
A family of bimmers
2745
Rep 7,741
nice vid. i also recommend the pop rivets. I picked up a little beefier plastic rivet at the auto store that was a GM part. Much more secure. I took the skirts off and did it. Only takes a few minutes each side to pop them off and then you can line everything up much easier.
11-19-2019, 09:23 AM | #7 | |
Rep 374
2024 X5 x40i
11-19-2019, 02:17 PM | #10 |
Rep 8,942
Instead of the plastic rivets you can easily use some standard aluminum ones available anywhere (I got mine at HD). Same install steps except you need a rivet gun, not expensive tool.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-20-2019, 04:14 PM | #11 |
A family of bimmers
2745
Rep 7,741
https://www.autoevolution.com/news/h...ets-60970.html
I just got 20 of those in the picture where it's a screw into the expanding section. Been on the car 2 years without any issue. Easy to remove as well
08-17-2020, 07:38 AM | #12 |
¯\_(ツ)_/¯
945
Rep 1,762
Bruceking07 couldn't attach pics in the PM
Excuse the dirt haven't washed my car in ages :/
08-17-2020, 01:50 PM | #14 |
¯\_(ツ)_/¯
945
Rep 1,762
You got it! Seems like that's how it's supposed to be
