05-20-2017, 04:41 AM | #24 |
Rep 211
Hi roxxor.
What do you mean??? Electric or folding!?? Mirror Electronics, Left – 67137438145 (Only needed if you are not swapping the mirrors) - Mirror Electronics, Right – 67137438144 (Only needed if you are not swapping the mirrors) |
08-23-2017, 07:07 AM | #29 |
Rep 466
10-01-2017, 05:52 PM | #30 |
Rep 7
Hi,
roxxor i have a problem i did all the steps but still i can successfully do the FlexRay initialization. And i don't see the module in e-sys or ista+. I have checked that to module get 12V power, and the FlexRay Signals cables are ok from the back to FEM and they are in the correct pin place, i have also checked if the FlexRay loop is ok. I coded every module with the new VO as you recommended. Every thing seems ok... after that i bought a new HC2 master still nothing BUT I've bought driver assistant panel with 2 more buttons with options i don't have (pre-collision, and some other shit) may that be the problem ? Is it possible that this create the problem ? I should also add that when i push the button it responds with a green led light and on the dash info that it will start working from 50km/h. This is the errors i get : Last edited by drapi13; 10-01-2017 at 06:12 PM.. |
10-13-2017, 09:03 AM | #33 |
Rep 7
Hi,
Thanks for the very detailed and informative post. Am still waiting for the driver assist switch (on/off) to arrive. Appreciate if you could repost the photo of where you have zip tied the switch module? Understand from your post that the stowage compartment need not be sacrificed. Thank you so much!! Last edited by xnap; 10-13-2017 at 09:18 AM.. Reason: Better understand of the post |
10-14-2017, 04:39 PM | #34 | |
Rep 5
It seems that the FlexRay channel can be unlocked with tool32 only. Ive tryed, but it's too complicated. Maybe someone who did it will post the exact steps to follow. |
10-18-2017, 12:53 AM | #35 | |
Rep 5
I still need to do some VCM coding, because if i run Flexray initialization with ISTA, the port 3 closes again, but, as i said it's a coding thing and if i don't run the Flexray initialization, everything works great except an error in the ZGW saying that Flexray isn't initialized. Thanks all for posting infos and PMd me. |
markqu0.00 |
10-18-2017, 02:56 AM | #36 | ||
Rep 36
11-13-2017, 06:58 AM | #38 |
Rep 36
12-02-2017, 10:03 PM | #40 |
Rep 48
12-14-2017, 03:20 PM | #41 |
Rep 466
Not sure if you can help me out. I followed the steps and VO coded my car. After VO coding it my ICM isn't responding, everything still works real time but when run ISTA its amber and when I test the ICM ecu it goes red. I'm not able to installize the flexrays since the ICM isn't responding. I have not used or familiar with tool32.
01-02-2018, 05:28 AM | #42 |
Rep 28
Will mirrors with LCW get the LIN bus controll unit?
Partnumber: 67 13 7 266 659 instead of 67 13 7 292 347 for left and 67 13 7 292 348 for right When it does we can probably code the mirror tilt function as well? |
Tags |
5ag, blind spot detection, lane change warning, steelerfan |
