06-16-2022, 12:56 PM | #23 | |
Rep 1,010
This another log and yeah it's much better and WGDC is lower too.
Which log is the latest ? Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
WrxToBeamerGuy492.00 |
06-16-2022, 12:57 PM | #24 |
Rep 942
06-16-2022, 12:59 PM | #25 |
Rep 1,010
Yes my friend though the boost leak was the better option
06-16-2022, 11:17 PM | #28 | |
Rep 942
If I do have a boost leak then I have no idea from where as I have taken apart and reassembled the charge pipe and entire intake multiple times without it changing my logs. I've even swapped back to all OEM on most of the logs. Also a 6.85s 100-200 on just e40 and a pure850 at 4,000 plus feet in the summer is nothing to sneeze at IMO. Especially since Dragy didn't correct for my altitude and assumed I was closer to sea level. |
06-16-2022, 11:21 PM | #29 | |
Rep 1,457
06-17-2022, 09:50 AM | #30 |
Rep 942
The reason I swapped back to oem is because I was getting a drive train malfunction and I thought it might be my aftermarket parts. It turns out it was the tune. I've since swapped back to Dinan coils, Dinan intake, and FTP charge pipe.
A charge pipe upgrade isn't required on this platform I just got one because I liked the red charge pipe. If I can make a recommendation it would be not to get the FTP charge pipe as it rubs and also doesn't have great fitment. Go with another brand. |
06-17-2022, 01:35 PM | #31 |
Rep 1,010
Dragy doesn't correct for altitude.
06-17-2022, 04:28 PM | #33 | |
Rep 420
M140IX. Turbo Pure 800 Cast.
06-17-2022, 05:32 PM | #34 |
Rep 1,010
Yes + you'll be able to run higher boost.
06-21-2022, 11:38 AM | #35 |
Rep 942
06-22-2022, 07:43 AM | #36 | |
Rep 389
Drives: 18 BMW M2LPower
E.T. and slope are always 100% accurate even without DA info.
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
07-02-2022, 02:21 PM | #37 |
Rep 942
Dyno run from today. I'm floored I was not expecting this power level.
Edit: I am thinking the dyno reads high and that I'm not making this kind of power based on dragy results and comparisons. Last edited by WrxToBeamerGuy; 07-03-2022 at 12:00 PM.. |
07-02-2022, 03:06 PM | #38 |
Rep 1,010
Nice, is that whp ? also do you a log for that exact tune so we can compare ?
07-02-2022, 06:33 PM | #39 | |
Rep 942
https://www.bootmod3.net/log?id=62a1...729b2c1234a989 |
Jay5k86.00 |
07-02-2022, 06:34 PM | #40 | |
Rep 298
17 BMW 340iX / DAW UF/ DS2 HPFP
07-02-2022, 07:28 PM | #41 | |
Rep 154
07-02-2022, 07:52 PM | #42 |
Rep 942
07-02-2022, 08:47 PM | #43 | |
Rep 329
is the motor built ? .. are u gonna xhp flash now ? |
07-02-2022, 09:30 PM | #44 | |
Rep 942
Motor is stock and I am xhp flashed stage 2. 99 percent of the time I'll run the lower power pump gas map. |
