BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding out passenger seat occupancy mat?
      07-19-2018, 12:49 PM   #1
zzarzzur
Drives: 2012 BMW 328i
I’ve got a 2012 328i that has a faulty sensor pad in the passenger seat that’s causing the passenger restrain malfunction error. Is there anyway to code out the sensor pad and force the airbags to be always on?
I ordered an emulator, but it won’t get here in time before my trip.
      09-20-2018, 03:39 PM   #2
rjmorales
Any update on this? I have a 2012 that’s doing the same exact thing.
      08-17-2019, 05:07 PM   #3
jordan35i
jordan35i's Avatar
Drives: 340i
Update? Same issue. Would be nice if it was possible to just code this out
CURRENT: '18 340i
      08-17-2019, 07:19 PM   #4
M3nt4l
Drives: BMW F20, BMW E91
Could try this, found on the net:
1. Disconnect sensor mat
2. Code > CIS_Beifahrer > nicht_akttiv
Vehicle Diagnostics and Coding
ISTA ESYS
CarPlay Activation
Sat Nav Map Updates
SLI FSC
      08-17-2019, 07:25 PM   #5
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Should already be on nicht_aktiv.
Although mine is untouched and it's already on nicht_aktiv.
You should rather play with the SBE_UP and SBE_DOWN paramaters.
Put these on FF, and like M3nt4l said disconnect sensor mat.
Then delete the fault messages.
It's an idea, not much more.
Edit: seen this from the following topic:
https://f80.bimmerpost.com/forums/sh....php?t=1371308
Passenger seat position sensor:
Sitzpositionsensor_Beifahrer: aktiv -> nicht_aktiv
airbag seat sensor
