BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Esys problem
      04-24-2018, 08:49 AM   #1
dengus
Drives: 320D f30 2013
Esys problem
Hi! I got an F30 with a retrofitted NBT EVO, all working perfect but is on Id5 and I want to code it to Id6.
Well when I read coding data I just get dots and it's not possible to do any changes.
https://flic.kr/p/258xQFH
I have try with all esys version I could, 3.27 3.28 3.31 3.31 I got full psdzdata 63.3 . If I connect on level 07/17 I can read but not code so I assume the NBT has been coded on 11/17 and on 11/17 I get the dots.
Any ideas??
      04-24-2018, 10:43 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
It has nothing to do with E-sys version or needed full psdzdata.
It has to do with either selecting incorrect chassis in Launcher Premium or not enough memory. If using premium launcher, go to %:\Data\psdzdata\kiswb and move or delete unneeded targets.
If using Pro Launcher, use settings to remove unneeded targets.
      04-25-2018, 12:31 PM   #3
dengus
Ok. Thanks I will try and let's see
      04-25-2018, 01:39 PM   #4
Almaretto
Almaretto's Avatar
2374
You are welcome. Report back to let community know if resolved or not.
Also, I recommend using E-sys 3.27.1. Newer versions offer no coding advantage and have some broken functions (eg, Caf injection, Coding-Verification, External Transmitter).
      04-26-2018, 11:54 AM   #5
dengus
Hi! I did what you advise me and it works! Thanks
      04-26-2018, 10:50 PM   #6
Almaretto
Almaretto's Avatar
2374
      07-15-2018, 01:28 PM   #7
Amur
Romania
Drives: BMW F10 2011 automat
E-sys
Hi
Someone can help me with a download psdzdata ful for E-sys
Thank you
      07-16-2018, 12:08 AM   #8
IK6SPEED
Drives: BMW M3 / AH3
Has this been corrected?
      07-18-2018, 05:10 AM   #9
Almaretto
Almaretto's Avatar
2374
No. Still using most stable version. No reason to update.
IK6SPEED4487.00
      07-18-2018, 10:54 AM   #10
IK6SPEED
What about updating istep?
      07-18-2018, 11:01 PM   #11
Almaretto
Almaretto's Avatar
2374
If Flash Programming, I use 64-bit 3.32.
For coding, I use 3.27.
      06-26-2020, 09:11 AM   #12
Rick4345
Rick4345's Avatar
470
Drives: 2022 WRX World Rally Blue
Tried to send you a PM.
Your message box is full.
Rick
