07-15-2018, 02:12 PM | #1 |
Rep 7,484
Photos as seen here:
Notes on a subwoofer install on an F32 with Harman Kardon https://f30.bimmerpost.com/forums/sh....php?t=1408166 1 x JL 12w3v3 2 ohm subwoofer (usually sells used from 150 and new for 330) 1 x enclosure - sits on amp side (new it would cost 100) 1 x JL mesh cover for sub (new more than 40) 1 x JL XD 600/1 v2 amplifier (used around 185 to start and new it was expensive). I don't have the boxes or invoices anymore. It all works and can be demonstrated and disconnected. I may still have the manual and hex key for the amp. Everything JL has a valid serial number. No wiring kit included as it would be a nightmare to remove. Same reason I cannot get rid of the LC2i but I might use that again as I like it. Collection only in West London. Paypal only. No returns. Sold as a package no separate sales. Total cost as a package: 400 Sorry not able to come down from that. New the system cost me more than 900 to put together. I used some expensive cables and the LC2i had to be imported from the USA with a Technic PnP harness. The enclosure is for an F32. It will not fit if you have a dvd changer above the amp tray. |
07-16-2018, 03:52 AM | #2 | |
Rep 148
Although sounds amazing it doesn't go quite as deep as a 12" would. What's your reason for sale if you don't mind me asking? And is the F32 boot shape the same as an F30 I wonder... |
07-16-2018, 04:32 AM | #3 | |
Rep 7,484
Edit. Compared part numbers. Trim panels are different sizes in F30 and F32. F32 being slightly longer. Might try to remove it and fit it in the F30 to check fitting. |
07-16-2018, 07:56 AM | #5 |
Rep 7,484
Looking at real OEM the trim panel is not compatible with the F36 so my guess would be no but I will try measure it in the week:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9380 |
01-29-2019, 07:44 PM | #6 |
Rep 10
Is this still avalible?
QUOTE=Chelsea_Tractor;23459489]Photos as seen here: Notes on a subwoofer install on an F32 with Harman Kardon https://f30.bimmerpost.com/forums/sh....php?t=1408166 1 x JL 12w3v3 2 ohm subwoofer (usually sells used from 150 and new for 330) 1 x enclosure - sits on amp side (new it would cost 100) 1 x JL mesh cover for sub (new more than 40) 1 x JL XD 600/1 v2 amplifier (used around 185 to start and new it was expensive). I don't have the boxes or invoices anymore. It all works and can be demonstrated and disconnected. I may still have the manual and hex key for the amp. Everything JL has a valid serial number. No wiring kit included as it would be a nightmare to remove. Same reason I cannot get rid of the LC2i but I might use that again as I like it. Collection only in West London. Paypal only. No returns. Sold as a package no separate sales. Total cost as a package: 400 Sorry not able to come down from that. New the system cost me more than 900 to put together. I used some expensive cables and the LC2i had to be imported from the USA with a Technic PnP harness. The enclosure is for an F32. It will not fit if you have a dvd changer above the amp tray.[/QUOTE] |
01-29-2019, 11:00 PM | #7 | |
Rep 7,484
Yes sir. |
01-30-2019, 11:33 AM | #10 |
Rep 9
02-03-2019, 12:51 AM | #12 |
Rep 7,484
02-04-2019, 01:11 PM | #14 | |
Rep 7,484
1. Technic wiring harness. https://technicpnp.com 2. LC2i LOC: https://www.amazon.co.uk/AudioContro.../dp/B00IIL0LW0 I purchased 1+2 directly from Technic. IIRC it came to £120 including customs fees. 3. Amplifier wiring kit of your choice. 4 awg would be my recommendation. |
