04-18-2014, 03:25 PM | #23 |
Rep 376
again, it is possible, I have done it as well as others, the risk is yours if you want to do it. I would certainly never offer to do it to someone else's car...
04-18-2014, 05:28 PM | #24 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
I was able to get launch control by only FDL coding it and it works fine but I'm on 51.3 so maybe the minimum I-step to get this working is 51.1 and not 50.4. Also, it doesn't just work right away; you need to have driven at least 6 miles to allow it to work. I think a lot of people who coded it just don't know how to use it properly. This is how you trigger it : 1) Drive at least 6 miles 2) Sport+ or DSC Off 3) Tilt Shifter to left 4) Floor the brake and the floor Accelerator (Yes! FLOOR IT. If you just press it, it will not work) 5) Let go of the brake and you will see the checkered flag I haven't coded this for anyone else but if it works on my 2012 328i on 51.3, it should work on any 2013 model.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 04-18-2014 at 06:08 PM.. |
04-18-2014, 06:12 PM | #25 | |
Rep 1,892
BTW, on step 5: I thought the checkered flag shows up BEFORE you release the brake indicating that LC was active and ready to go. |
04-18-2014, 06:20 PM | #26 | ||
Rep 1,892
Since Shawn indicated that the build date is only used during VO coding, how did changing the build date enable launch control for you if you didn't VO code your EGS with it? |
04-18-2014, 06:54 PM | #27 | |
Rep 1,976
I actually suggested to change the build date to 07/13 and VO code EGS before I tried it on my own car the same day. That's when I got the transmission heating error and that's when I said not to do it later. What I meant to say is that the software on 2014 cars and 2012/2013 F30's are all the same and the build level kind of acts a filter for ISTA and E-sys to code according to the build level. That doesn't mean that you can't FDL code these features. If you have someone with a 2013 F10 with a build date of 03/13 and the car has been flashed to 52.1, it will not get the volume bar or album art over Bluetooth on the NBT but those features are actually on the new firmware and it's just a matter of either FDL coding it or VO coding it with a modified build level to enable them. Hope this clears things up.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
04-18-2014, 06:59 PM | #28 | |
Rep 1,976
timk12313.00 |
04-30-2014, 07:49 PM | #30 |
Rep 387
How do you check the version?
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
02-06-2016, 07:02 PM | #32 |
Rep 15
So can We go to the dealer and get it?
Ok so can we just get a software update from the stealer, or do we already have launch control on a 2013 BMW 328i/xi? does the car need the sport line? Mine is the luxury line. goes like hell vs my 2004 ford focus
HerrJatoba4.50 |
04-13-2016, 11:08 PM | #34 |
Rep 1,986
04-14-2016, 03:04 PM | #35 |
Rep 191
Drives: 2020 BMW X5 S40i
From my 2016 F32 Manual...
04-20-2016, 11:41 AM | #36 |
Rep 157
What does it mean to "allow the transmission to cool for 5 minutes" before using launch control. Kind of confusing or I'm just over thinking it. Do I just idle for 5 minutes before trying this out? I have an F30 sport line and have been waiting till I get to 20k miles to do this.
04-21-2016, 02:31 PM | #37 | |
Rep 436
Drives: 2016 435i xDrive Gran Coupé
06-19-2016, 01:28 AM | #38 |
Rep 117
So I've tried on stock (before coding) and after coding multiple times, and I just can't seem to get launch control to work. Interesting how my 2013 335i owner's manual indicates I do have it and instructs on how to enable it...
06-20-2016, 02:54 AM | #39 |
Rep 143
I enabled it on my F31 diesel car.
Does anyone know if the LC works on the 5 series? |
Onizukachan1086.00 |
07-10-2016, 09:04 AM | #40 |
Rep 5
Hello,
is there also any possibility to get launc control activated on F10 535i MY 2011 ? I updated all of the cars ECU-s on my dealer, newest I-level now. I was abel to code LC_active in EGS, I also retrofitted 2TB to VO and VO coded the car with that 2TB! Btw my car has no GWS module highlited in the list, no CAFD-s there. Still when I jam the brakes on Sport + and hit the gas to klick/kickdown then @ 1500-2000rpm the rear wheels are start to spin while the brake could not hold them not spinning. This function is not working on my car... Siim |
10-25-2017, 03:06 AM | #41 |
Rep 2
I have F30 328i from 2012/07 and the Launch Control cannot be coded because of I-Step ver. 44.3 ..while minimum required for LC is 50.4. Switching 205 to 2TB and changing build date from 07/12 to 07/13 doesn't fix the problem obviously in this case.
I'm going to flash EGS using using E-sys 3.28 with ENET cable. I have backup files from original state before I started coding adventure with my car. 1. Do I need to flash other ECUs also? 2. Which version of PSDZdata do you suggest - 50.4 or can I use any even latest available? 3. Do I have to return initial VO/VA coding using by backup files first? 4. What errors should I expect after flashing and what additional tools should I arrange to fix them (ISTA-P ? or so) ? |
06-22-2018, 01:02 PM | #44 |
Rep 95
Not only does the car have to be in sport + but make sure the shifter is to the left on Manuel/sport. Also very important gas pedal must be all the way to the floor while pressing the brake hard.
I could be wrong but I thought all f30s come stock enabled. Edit: I am wrong, needs to be coded in |
