BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Best Mods for track day
      02-20-2020, 03:20 PM   #1
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
Hey everyone, I'm curious about tracking my F30 335i for the first time and was wondering what would be the best mods for it. I'm already FBO and have KW coilovers with SS brake lines and EBC pads. Is there anything else I should look into? Thanks for the help
2013 BMW 335i xDrive: [Sold]
      02-20-2020, 05:22 PM   #2
FaRKle!
Which EBC pads, what brake fluid, and what tires do you have?
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      02-25-2020, 10:50 AM   #3
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
RedStuff Pads, Motul RBF 600, and Hankook Ventus V12
      02-25-2020, 10:55 AM   #4
FaRKle!
You'll definitely want different brake pads for the track. EBC reds are fine for spirited street/canyon driving, but won't hold up to repeated threshold braking at the track. I found what their limit was when bedding my street set, and that strongly convinced me they aren't to be used on the track.
The next "mod" I'd do is dial in your suspension damper settings so that the ride is smooth but controlled. That means not going too stiff, where you're actually decreasing your tires' grip.
      02-25-2020, 11:05 AM   #5
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
Sounds great thank you
      02-25-2020, 10:54 PM   #6
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
Are you going as part of a school like the BMW CCA or Bondurant? Or is it just an open track day?
If the former, just make sure your tire pressure is to spec and maintenance is up to date.
You WILL find your car will do more than your skillset allows.
If the latter... see if you can get a more senior driver (like an A-class person) to ride along with you and give you seat feedback.
I've personally found that just exploring a track can be fun, but you hit a threshhold pretty fast in the day. But with an instructor, your skill level improves dramatically.
      02-26-2020, 08:10 AM   #7
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
It would be just an open track day. thanks for the advice
      02-28-2020, 06:39 PM   #8
jmg
jmg's Avatar
18704
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
What tires are you on? All those mods don't mean much if you don't have traction.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      03-03-2020, 10:35 AM   #9
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
Currently, I'm on Hankook Ventus v12 evo2s
      03-03-2020, 10:53 AM   #10
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
I would definitely look into upgrading your tires. Those Hankook's are decent for the price, but you're not getting all the power to the ground you could be.
If you don't want to get dedicated track tires, in the least, get better street tires like MPS4S. RE71R's are currently the hot tire for track use and occasional street use. They wear faster but perform just as well as NT01's but are still good in the wet. I'm currently on MPS4S but I am looking to get RE71R's on my M3 CS for track use.
On the flip side, if this is just an open track day and your first time, just use what you got! The Hankooks will do just fine and the most important thing is to work on you as a driver before you start thinking of dumping money on mods. Tires would be my NEXT move however if you continue to attend track days.
IG: Raging_G82
      03-03-2020, 11:20 AM   #11
GPwhips
BMW Enthusiast
GPwhips's Avatar
Drives: Volvo V60
Sweet! thanks for the help
      03-03-2020, 10:31 PM   #12
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
stock is 100% fine for a track day, you will have a blast just enjoy it.
      03-04-2020, 10:08 AM   #13
MacklinUSOB
Drives: f30 328i 6MT Sport
For the first couple of track days you won't be pushing that hard so stock is a good place to start.
As Farkle mentioned, once you start getting faster the RedStuff will not keep up. Once they overheat they wear extremely fast and can totally screw your rotors. My car is several hundred pounds lighter than yours and that was my experience. I lost about half the material on one track day.
Past: E36 328is & E38 740i
      03-04-2020, 11:01 AM   #14
FaRKle!
My experience when I overheated the pads was even scarier, the car wouldn't stop!
      03-05-2020, 06:53 PM   #15
zinner
zinner's Avatar
I have been happy with stoptech sport pads. A lot depends on the track you are driving on how far you need to take braking mods.
      05-15-2020, 10:46 PM   #16
ClevelandBeemer
ClevelandBeemer's Avatar
94
Drives: 2013 BMW 335i M-Sport
2021 BMW X5 45e  [0.00]
2013 335i  [0.00]
2015 BMW S1000R  [0.00]
After tires I would get an LSD to compliment your suspension setup. The lack of LSD has a serous impact on lap times in tighter courses. Also camber plates if you get really serous about the track.
      06-04-2020, 03:24 PM   #17
Polo08816
Drives: 2014 335i M Sport
Those MPS4S won't hold up to the heat of a track day. RE71Rs wear out too fast. RE71Rs will put a lot of wear on suspension bushings because of the amount of grip.
      06-04-2020, 03:49 PM   #18
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
MPS4S should be fine for a beginner like the OP and are much better than the Hankook v12's he is running. You get what you pay for. I've done several track days on a new set of MPS4S and they are holding up just fine so long as you don't overdrive them. My main concern was Op has full FBO and a list of mods but forgot the most important one: tires.
Guaranteed the Hankooks are going to get greasy, not that MPS4S won't either, but at least you will better good grip up until that point. The Evo2's won't performa as well and still get greasy. They are a good bargain performance street tire, but they simply aren't a track tire.
Of course RE71R's wear faster than street tires, you're not going to get a sticky track tire that's gong to last 20k miles. Gotta pay to play and compared to the Yoko A052's they last longer. RE71R's are not slicks, they have a much more progressive break away and don't require as much from the stock brakes as slicks, but you are pushing your car much harder and for longer than on the street and your car will have more wear and tear, wear and tear is just part of the sport.
In the end, though I defer to what zinner posted–OP should just go with what they have for now, have fun and think about upgrades after they get more seat time.
IG: Raging_G82
      06-04-2020, 07:29 PM   #19
Polo08816
Most people seem to get 8 track days out of the RE71s at best.
I would like to see some more reviews of the S007A. Won't be as stick as RE71s but maybe last a bit longer... idk.
      06-05-2020, 03:25 AM   #20
nickf30
Drives: 2014 335i xDrive
Get Hankook RS4 or Maxxis VR1 for track day last way longer / more consistent than autoX / time attack tire like RE71R/A052
      06-05-2020, 11:30 AM   #21
jmg
jmg's Avatar
18704
2019 i3 BEV  [0.00]
All depends on your budget. 8 track days is about right for what you get, which is NT01 levels of performance you can drive to and from the track even in the wet.
IG: Raging_G82
      06-05-2020, 12:41 PM   #22
FaRKle!
I went like 12-14 track days on R-S4s, and could've gone more if I had camber plates at the time or flipped the tires on the wheels.
I'm at 5 days on NT01s right now. Lots of life left, but I'm not convinced it's a faster tire than the R-S4s were. That could be due to just how wide of a tread width the R-S4s have in 245/40-18 though. It's definitely easier to overdrive the R-S4s before NT01 though.
