03-25-2020, 12:36 PM | #23 |
Rep 4,329
[QUOTE=DreamerJoe;25967247]question on the spacers, will the 10-12mm/15mm make them fit like OE, or will they fit flush?[QUOTE]
depends on the tire size combination you select. if you are stock suspension or mildly lowered, i'd recommend 235/40/19-265/35/19 tire size combo with 12.5 mm front and rear. equivalent offsets +32.5 front, +39.5 rear if you are moderately to aggressively lowered, tire size combo of 245/35/19-275-30-19 with 15mm front and rear. equivalent offset +30 front, +37 rear. other tire size or spacer combinations are possible, it's just what i'd do again, a stud conversion kit makes things way easier with spacers. |
03-25-2020, 12:48 PM | #24 | |
Rep 4,329
also, i'd save up for some decent quality rotary forged wheels that are attractive to you, instead of low-pressure cast reps. |
03-25-2020, 02:29 PM | #25 | |
Rep 3,748
This is what I think.... you should get it... run those spacers alohasurftoad mention 12.5mm (stock) or 15mm (lowered). Why... because $550 for a VMR v804 with tires is a crazy deal. And I bet someone will buy it from you if you resell it just to recoup what you spend and it's also a plus that the spacer you get you can either sell or use it with your original 400m. This is what I would do if I am presented with this delema but someone has there own opinion. Edit: I'll go with 12.5/ 12mm spacers... I just notice your on an F30. I was imagining the wheels on my F36. I'm conservative, I don't like hitting/rubbing on anything, those super flush look can throw rock on your bumper or quarter panel Last edited by Gen13 F36; 03-25-2020 at 02:38 PM.. |
alohasurftoad3078.00 |
03-25-2020, 03:07 PM | #26 | ||
Rep 764
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-07-2020, 05:38 PM | #27 |
Rep 764
So, I picked up the wheels and will be ordering Dinan springs w/ Koni yellows and just want to clarify something for the spacers. the tire sizes are 225/35/19 front and 255/30/19 rear, will the 12.5mm spacer give me oem fitment like what I currently have or closer to the fender more flushed fitment?
05-16-2020, 10:31 PM | #28 | |
Rep 764
HUGE thanks to alohasurftoad, the 12.5mm spacers front/rear came out perfect, lower the car to above a 1/2 inch all around and 1 side needs to be adjusted. the fitment came out perfect though, just want to go get tires with a slightly taller sidewall because right now the front is .8" smaller overall diameter and rear is 1", and profile is a little low for my liking.
05-16-2020, 10:36 PM | #29 |
Rep 764
tried attaching to previous post but I don't think it worked.
05-17-2020, 12:09 AM | #30 |
Rep 4,329
very nice. 5-Y spokes are my fave. wider, higher profile tires will close the gaps and look epic.
looks like 245/35/19-275/30/19, would work nice, no issues. best rear width for the power you're making. 245/35/19-255/35/19 would work as well, guarantee no issues. 235/40/19-265/35/19 will have the gaps real tight. in theory, the rear should not rub the fenderwell lip however when i visualize this size combo on your pics, i feel it could rub under compression. fronts would be fine. im a leery of recommending this size based on the current pics. if you can get some clearer shots, level with the gap height, quartering view would be better to determine. Last edited by alohasurftoad; 05-17-2020 at 12:17 AM.. |
DreamerJoe242.00 |
05-17-2020, 12:28 AM | #31 | |
Rep 764
front tire size went from 225/45/18 to 225/35/19 thinking of going up to 35 rear and 40 front on the sidewall, will use the calculator to see how 235 and 265 width increase with larger sidewall will impact the size difference. right now I'm feeling a lot of vibration from the road, bumps are smooth but I feel the grains, rocks and tread of the road, I'm thinking it's alignment, the smaller sidewall, or both making me feel the vibration. I'll be getting the alignment done on tuesday and hopefully that helps, if not new tires will be coming sooner rather than later, was hoping to get a few months on these tires because they still have a lot of life left. and I'll get some more pics tomorrow, as a bonus the shop had a brand new rear diffuser that another customer changed his mind on, so I got that as well for a good price, not carbon but I like thr more aggressive and subtle flat black more than carbon there.
05-17-2020, 01:52 AM | #32 |
Rep 4,329
nothing wrong with 225/40/19-255/35/19 as it is the OEM tire size combo.
although 245/35/19 is 0.2" shorter than 225/45/19, the 245 tire shoulder pokes 10mm further out and fills the 3-dimensional gap. compared to 225, the extra width of 245 provides a lot more front grip providing much higher cornering speed before "pushing". a 275/30/19 is 0.5" shorter than 255/35/19 however it's shoulder is 10mm more poke which fills gap. here is 245/35/19-275/30/19 similar wheel offset, lowered on KW V1. i believe you'd have slightly more gap with dinan. https://f30.bimmerpost.com/forums/sh...9&postcount=12 Last edited by alohasurftoad; 05-17-2020 at 01:58 AM.. |
05-17-2020, 07:15 AM | #33 |
Rep 764
I think I'd rather go with benefits of a larger sidewall vs width, unless going just a step up on both isn't too much, it was like .3 and .4 larger overall diameter in the tire calculator. Also, I ended up going with ST XA coilovers, I was too undecided when reading about the pros/cons of different spring/shock combos and heights vs base vs m sport and which spring will get me where.. then it was just and extra $150 for coilovers, and another $160 for adjustable.
05-17-2020, 10:51 AM | #34 |
Rep 4,329
coils, perfect...if you have coils I'd definitely use 235/40/19-265/35/19. You can just set the height/gap exactly as desired.
here is 235/40/19-265/35/19, ET30-ET45...https://f30.bimmerpost.com/forums/sh...2&postcount=23...if you can visualize, your front tires would be 2.5mm more tucked, rears would be 5.5mm more poke than his. you can also set your ride height and gaps to be a little tighter with coils. or you could also do 245/35/19-265/35/19...here on ET32-ET40, so basically same offsets as yours... https://f30.bimmerpost.com/forums/sh...F19+265%2F3519 Last edited by alohasurftoad; 05-17-2020 at 11:36 AM.. |
05-17-2020, 05:51 PM | #35 |
Rep 764
I got some more pictures, took 3 angles per tire. hope they came out in order BL, FL, BR, FR.
05-17-2020, 06:54 PM | #36 | |
Rep 4,329
1st) 235/40/19-265/35/19, 26.4"-26.3" 2nd) 245/35/19-275/30/19, 25.8"-25.5", (i understand you prefer it taller) 3rd) 245/35/19-265/35/19, 25.8"-26.3", best handling, M2 specs, forward rake, gaps can be evened with coils. 4th) 245/35/19-255/35/19, 25.8"-26.0", semi square, least understeer 5th) 245/40/19-275/35/19, 26.7"-26.6", too tall for my taste, can reduce gap and appear lowered although it's actually higher. 6th) 225/40/19-255/35/19, 26.0"-26.0", OEM size, 225 front is too narrow for my taste, causes understeer and being slightly stretched on 8.5" increases 3D gap slightly. however if you prefer this size combo is all that matters. Last edited by alohasurftoad; 05-17-2020 at 07:02 PM.. |
DreamerJoe242.00 |
05-17-2020, 07:15 PM | #37 | ||
Rep 764
05-17-2020, 07:33 PM | #38 |
Rep 764
and a wierd thing that happened is the TPMS sensors that were in the new wheels didn't work with my car. right now I looked on ECS tuning and it showed all Fx tpms as compatible from F22-F34, but when the installer tried programming it didn't work, and he used a snap-on sensor that was able to find my sensor under "F30" category, and the new wheels under "F22", but not vise versa. He's going to swap them on tuesday when I go back for alignment anyway, just thought that was kind of odd.
05-17-2020, 08:46 PM | #39 | |
Rep 4,329
here's what the valve stems caps look like. HUF says alligator germany Last edited by alohasurftoad; 05-17-2020 at 09:04 PM.. |
DreamerJoe242.00 |
05-22-2020, 12:44 AM | #40 | |||
Rep 764
05-22-2020, 08:25 AM | #41 | |
Rep 237
I feel like I could fit more tire, but would have to go up with the 3mm spacer in front and really scrutinize the clearance in the wells. I would go up in sidewall profile before thinking about width as 235 and 265 are correct for 8.5 and 9.5 |
