05-17-2016, 07:37 AM | #1 |
Rep 435
Upgraded All Modules, Few issues
First much thanks to Shawn for getting me to this point.
my car's ship i-step is F020-14-03-503 the dealer had previously updated me to F020-14-11-505 I flash updated to the most recent version, using psdzdata 58.3 It took a few attempts but every module is updated. If i re-calculate tal it shows no modules needing updating. If i check my i-step version it still shows F020-14-11-505 though and i am not sure why. i have 2 outstanding issues. 1. The front turn signals do not work. I have read in another forum that the LED lights need to be learned/taught. I am currently downloading rheinogold to try and accomplish this. i do not have that program currently so if there is a way to do it with esys that would be great, otherwise i will persue getting this to work. 2. The airbag light is flashing red but there is no error on the idrive. I am going to try and read/clear codes here in a second but i did try locking with: 1) Click "External Applications" in the left menu. 2) Click "External Application" 3) Double-click "Transmitter" 4) Double-click "ACSM verriegelung_schreiben" seems that things are a bit more involved then people suggest with the newer cars =) |
05-17-2016, 07:56 AM | #2 | |
Rep 3,947
05-17-2016, 08:41 AM | #3 |
Rep 435
Update.
The airbag issue is cleaned up. I did the following: Tool32 => ACSM4.prg => steuern_verriegelung_schreiben = control_lock_write 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\ACSM4.prg 4) In the "Select Job: F01" window, select steuern_verriegelung_schreiben (steuern_verriegelung_schreiben = control locking write) 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" At that point an error about airbag malfunction appeared on iDrive (it had not previsouly) Once i cleared codes with esys they stayed away. Just down to the turn signals. |
05-17-2016, 10:49 AM | #4 |
Rep 341
Rheingold ISTA+ will resolve all the issues with ENET. Scan the car for faults and run the tests plans for each fault and you will be back in business.
05-17-2016, 12:13 PM | #5 |
Rep 435
As f30gtr stated i was able to get everything up and running with Rheingold. One remaining item is that the i-step actual version is still the old version. I know all modules have been upgraded and a tal calc shows nothing needed to be done in esys. Is there some place i need to set the i-step value? Since you can upgrade modules piecemeal it seems likely that at some point you have to change this value manually..
05-22-2016, 05:18 AM | #6 | |
Rep 3,945
Drives: 2015 M4 MG/SO
Since you haven't done it, you can still change I-step in Esys, "Expert mode > VCM > Master > I-steps < Write". Our resident coding expert says it is not necessary to update it after a full update, but I will still do it if it bothers you. Last edited by aboulfad; 05-22-2016 at 05:37 AM.. |
05-22-2016, 08:10 AM | #7 |
Rep 435
thanks, i did have that option selected, however after hitting the start button in tal processing a box popped up with 3 different i-step version fields. I did not alter any of them, i believe i would have had to manually change the after i-step value manually to the new version for this to have done it on its own. I did change it manually with e-sys as you indicated.
