06-08-2020, 12:46 PM | #1189 |
Rep 40,765
06-08-2020, 04:16 PM | #1190 |
Rep 99
Quick question. I have a 428xi (f36)
I had an earlier version (early 2019) of ISTA+ and the newest psdzdata at the time on my old laptop. I installed the latest of all (march of this year) and it connects, diagnoses, etc and will even realize that I have newer software for my car, and calculate measures. It will not however let me actually perform the update, the button is greyed out. I have good voltage, etc. But I cant for the life of me figure out why it wont let me execute measures. Have they changed anything in ISTA that requires use of an ICOM? I know last years version didnt, because I used it, but it was something suggested but never confirmed as far as I could see. Thanks! |
06-08-2020, 04:22 PM | #1191 | |
Rep 40,765
hollovoid746.50 |
06-08-2020, 04:27 PM | #1192 | ||
Rep 99
Thanks for the reply! |
06-11-2020, 09:01 PM | #1193 |
Rep 6
What is the latest version of PSDZ lite and what version of ESYS do I need to run it. I have 3.27 ESYS and my buddy wants me to code his G01, I know what I have works on Fcars but I haven't tried G series yet. I am using ESYSx so I know I can run a newer version of ESYS.
Thanks |
06-11-2020, 09:14 PM | #1194 | |
Rep 40,765
06-11-2020, 09:34 PM | #1196 |
Rep 40,765
06-16-2020, 05:24 PM | #1198 |
Rep 40,765
PM sent.
06-16-2020, 05:57 PM | #1201 |
Rep 40,765
Ok. Make sure you installed full correctly.
06-17-2020, 07:06 PM | #1204 |
Rep 40,765
PM sent.
06-18-2020, 08:59 AM | #1206 |
Rep 40,765
No Kombi shows, not BKOMBI or KOMBI?
06-22-2020, 03:26 PM | #1207 |
Rep 5
Hello,
I am using esys 3.30.1 with launcher V2.8.1.155 I coded several cars succesfully but came to a problem recently: My uncle's F31 got back from service (BMW Dealer) this March and lost his coding ,DRL rear activated, digital Speedometer, temp in the cluster etc. This because the I Step got updated with standard coding I guess. I tried recoding the functions. At first I failed because i didn't have the correct cafd files. After updating to PSDZdata 4.22, I managed to recode the digital speedometer in the cluster but failed to activate the rear DRL's in the REM ecu. I can get in to edit fdl, change the functions and save it. After i click code fdl I get the error: processed with error,not executable What am i doing wrong? could it be the action below? - PSDZdata updating: I updated the PSDZdata as following. Copy the CAFD files to folder C:\Data\psdzdata\swe\cafd Should I do something else to update the PSDZdata? Like i said it worked with other ecus also after the update It would also be nice to be sent the latest PSDZdata can you help me out? thank in advance Last edited by BMW_HM; 06-22-2020 at 03:38 PM.. |
06-22-2020, 03:48 PM | #1208 | |
Rep 40,765
Code FDL Error means you choose invalid FDL parameter. Change them one by one to narrow down which one is problem.
06-22-2020, 04:32 PM | #1209 | |
Rep 5
its about cafd_000007a1_005_044_017. I have changed one code MAPPING_TAGFAHRL_H.. _L.. OUTPUT to SL/L, again the same issue. Maybe if I copy a new CAFD it will work? Could you please send me the latest PSDZdata? |
06-22-2020, 04:42 PM | #1210 |
Rep 40,765
Won't matter, but you can try. PM sent.
