04-17-2019, 09:31 PM | #1 |
Rep 2,357
PWG with Pure Stage 2 running flash only
Hi
Anyone with a PWG car running Pure Stage2 on flash only? Where was it tuned and do you have logs to show?
(A Dane in China) Last edited by harkes; 04-17-2019 at 11:22 PM.. |
04-18-2019, 06:32 AM | #2 |
Rep 316
I am...Running through the motions of a custom tune with Twisted. So far base map targeted 18.5 PSI so logs of course weren't ideal, will report back once he adjusts. However, it already feels better than JB4 + BEF
04-18-2019, 08:09 AM | #3 |
Rep 2,357
Hitting boost targets?
(A Dane in China) |
04-18-2019, 08:30 AM | #4 |
Rep 316
Up until about 4500-5000, then the stock fueling can't take it and boost drops significantly. I'm hoping he adjusts down to 16 or so across the board and it will feel great.
04-18-2019, 11:16 AM | #5 |
Rep 2,357
Ok, I'd be very interested in seeing the final result. So please share if you are OK with that
(A Dane in China) |
04-18-2019, 04:54 PM | #7 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
04-18-2019, 06:35 PM | #8 |
Rep 470
I am flash only on my F25, but I am tracking down an issue that is either in the wastegate actuator or the vacuum control system.
All I know is I'm having difficulty getting above 13 PSI and boost tapers significantly past 5K RPM. these cars are a nightmare when you have an issue like this because it's not obvious what causes it. Oh, and there's no boost leaks. Was tested up to 20PSI no problem.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
04-18-2019, 06:37 PM | #9 | |
Rep 2,357
(A Dane in China) |
04-18-2019, 06:50 PM | #10 |
Rep 949
Just throwing it out there but they've made some JB4 adjustments for the often problematic PWG cars. The new V2 systems are now fully integrated on boost control so you can set the basics in the flash and use the JB4 just for fine tuning like it was meant to be. No more of the F series PWG ISO stuff that was difficult to get perfectly dialed in.
04-18-2019, 06:52 PM | #11 | |
Rep 2,357
(A Dane in China) |
E92only82.00 |
04-18-2019, 08:45 PM | #13 |
Rep 470
Current mods
04-18-2019, 09:28 PM | #14 |
Rep 2,357
So you suspect the map to be the culprit? I got plenty of boost - 27psi peak in some of the revisions haha But the WGDC seems VERY tricky. My tuner just re-wrote the tables so fingers crossed for v20
I am a part of the MHD PS2 OTS beta-testing also. Their v22 is working very nicely with my car so I use that for daily between custom maps.
(A Dane in China) |
dr.roro195.50 |
04-19-2019, 09:58 AM | #15 | |
Rep 470
Current mods
04-19-2019, 07:27 PM | #16 | ||
Rep 2,357
(A Dane in China) |
04-22-2019, 04:57 PM | #17 | |
Rep 470
Has anybody else here dealt with boost leak issues caused by a bad/stuck pcv?
Current mods
04-22-2019, 09:24 PM | #18 | |
Rep 2,357
(A Dane in China) |
05-15-2019, 11:14 AM | #19 |
Rep 470
No PCV problem. Well, there was, but it was caused by a vacuum leak on the exhaust flap mechanism. Now I know a fun way to fuck with someone
Anyways, here's a log: http://www.bootmod3.net/log?id=5cdba7b7c090c60cce3b4882
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' Last edited by doodlebro; 05-16-2019 at 09:28 AM.. |
05-16-2019, 12:46 AM | #20 |
Rep 2,357
Any update? Tuning still in progress?
(A Dane in China) |
05-16-2019, 02:18 AM | #21 | |
Rep 2,357
(A Dane in China) |
05-16-2019, 09:27 AM | #22 |
Rep 156
I have a PWG with PS2, but I have the TTFS HPFP...
Im peaking at 25psi but holding 19-20 to redline. Just added meth, so maybe adding a little more once setup. |
