05-02-2019, 09:53 PM | #155 | |
Rep 2,354
(A Dane in China) |
Munchi435i484.50 |
05-03-2019, 09:05 AM | #156 | |
Rep 1,105
B58 = $350 VS. XDI-35 = $2000 Decisions.....Decisions!! OEM plugs that came with the car and most likely have never been changed, going on 51k miles so far. But I'm going to be swapping them out before summer officially hits here in Florida!!
05-03-2019, 09:08 AM | #157 | |
Rep 1,105
Here is a custom map log that im currently running: https://datazap.me/u/munchi/ps2-test-22
05-03-2019, 09:11 AM | #158 |
Rep 1,105
I know MHD does and would think BM3 does as well....
05-03-2019, 11:51 AM | #159 |
Rep 6
I have written to BM3 and they responded that they don't have PS2 OTS map for EWG.. They probably have a Stage 2H OTS map for PWG PS2.
05-03-2019, 12:58 PM | #160 | |
Rep 1,105
I know MHD has OTS maps for the EWG PS2 and are currently developing PWG PS2 OTS maps. You might be better off getting a custom tune to use the PS2 on BM3 OR run the OTS maps until you've finished your build.
05-04-2019, 04:59 AM | #161 |
Rep 282
today some more testing with beta PWG PS2 OTS maps from MHD .
i'll post both logs later on so you can compare between custom and ots . pls do know its in development fase
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
Tricki215.00 |
05-04-2019, 07:47 PM | #163 |
Rep 282
MHD OTS Beta for ps2
https://datazap.me/u/thomas/log-1556...og=1&data=4-21 My custom wedge tune https://datazap.me/u/thomas/log-1556...og=0&data=4-21 both have two logs , full and partial throttle and yes i'm currently on 93pump and B58 hpfp
05-04-2019, 08:09 PM | #164 | |
Rep 128
05-04-2019, 09:32 PM | #165 | |
Rep 472
https://datazap.me/u/mattspies/log-1...8;zoom=101-202 My log is E20 with stock Fuel pump... i love a good looking log... i think |
05-04-2019, 09:42 PM | #166 |
Rep 184
I will be using BM3 Cary Jordan is looking into this as an option now as well.. I hope by the time im ready to do a custom tune ...the b58 will have proven yay or nay.. its starting to look like it is though. as a mild upgrade
05-05-2019, 05:12 AM | #167 |
Rep 282
in a few days i will test with 10 percent toluene ( oct 115 )
to see what timings will do
05-05-2019, 05:21 AM | #168 | |
Rep 282
for ps2 and e20 i need xdi for sure
05-05-2019, 05:24 AM | #169 | ||
Rep 472
05-05-2019, 05:27 AM | #170 |
Rep 282
around 18 also , but never got there in the first place
b58 is only a little bit better compared to stock hpfp
05-05-2019, 05:31 AM | #171 |
Rep 472
05-05-2019, 05:35 AM | #172 |
Rep 282
check the n54tech topic ( n55 section ), theres a guy who maxed his stock turbo on an M2
it was either e30 or e40 he ran
05-21-2019, 02:41 PM | #174 | |
Rep 4,510
On E20 your logs show you are at 15.6-16psi. Going to E40 and expecting 18psi is a big ask based on yr current set up - what changes are you going to make to get the most out of E40 blend ?
Current '22 X3M LCI.. |
05-21-2019, 02:56 PM | #175 | ||
Rep 472
In saying that ive done a deal on a M2C and within a week my car will be gone |
05-22-2019, 09:54 PM | #176 |
Rep 184
looking at some logs and some XDI logs.. thought.. it appears that the rail pressure could have a few hundred PSI sustained.. and while we know a PS2 turbo can run on stock fueling seems like it is a possible small bump for those not wanting to go nuts ( got my ps2 cause i had to warranty out my stock turbo )
