04-25-2019, 08:40 AM | #68 |
Rep 1,170
No update yet
bmw m2
04-25-2019, 02:59 PM | #69 | |
Rep 575
We both had JB4 no issues, just stating the facts. |
04-29-2019, 03:19 PM | #70 |
Rep 1,170
so here is the update:
so finally my mechanic was able to get to my car today at the dealer he diagnose the whole car he reprogrammed the entire car and calibrated the injectors and the car went back to normal back to normal idle and normal driving no back fires no misfires on nothing no codes nothing. so he found it very weird what was going on , he has no clue what was the issue to this or why it even start to do that so im happy it wasn't something deep or something really bad with engine failure or something like that. so now im kinda sketched out idk if i should really sell my bm3 or give it another shot. should i give bm3 another shot or do you guys think it will fuck my car up again lol? does anyone kinda know what happen to my car lol he is telling me i need walnut shell blasting for sure tho. so while my car is there i am going to do walnut shell blast oil change and alignment.
bmw m2
stroker1562.50 |
04-29-2019, 03:26 PM | #71 |
Rep 426
Glad to hear they were able to fix it without much issue. I guess I can't really tell you if you should or should not re-flash. Caveat emptor, I guess.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
04-29-2019, 03:34 PM | #72 | |
Rep 1,170
Or just leave it alone and maybe try another tune or idk I'm just sketched out to flash it and it messes up my programming of the car again or idk exactly but then I have to call my mechanic AGAIN and say the same issue returned once I flashed it He will be like come on man lol
bmw m2
BeerHerder250.50 |
04-30-2019, 06:00 AM | #73 |
Cheapskate
4450
Rep 4,993
So all he did was reflash stock software? What do you mean by "recalibrate injectors?" that sounds like bs
04-30-2019, 09:17 AM | #74 | |
Rep 1,170
bmw m2
04-30-2019, 01:17 PM | #75 |
Cheapskate
4450
Rep 4,993
Yeaaaah I'm not seeing that. If he just cleared codes and reset adaptations ok, but not sure about re-calibrating the injectors. Did you replace them?
04-30-2019, 01:18 PM | #76 | |
Rep 1,170
And I was getting misfires on one and 6
bmw m2
04-30-2019, 01:28 PM | #77 |
Cheapskate
4450
Rep 4,993
Ah gotcha, I missed that somehow. But doesn't explain why it was misfiring before swapping injectors even if it was necessary.
04-30-2019, 01:36 PM | #78 | |
Rep 1,170
I was so confused my self I honestly thought it was something else I couldn't figure it out I was so weird The car was running great I put bm3 and that's it the car panicked it was over boosting like crazy Timing was way way way toooo off Then that started to happen put the car back to stock and didn't make a difference And I changed out spark plugs Changed out a coil pack didn't make a difference Changed out 2 injectors didn't fix the problem Intill my friend at the dealer did that
bmw m2
05-04-2019, 12:38 AM | #79 |
Rep 1,170
hello you guys so i got my car back today the car feels great running smooth like butter so i decided to give bm3 one last chance and see how my car reacted to it before i just went ahead and sold it
im not going to lie i was kinda scared so i wasn't able to get full wot pulls because obviously the trust is not there yet. here are some logs if i can please get some feed back on how these logs look if my car looks healthy etc. with afr boost timing etc. here are some logs http://www.bootmod3.net/log?id=5cccfddbc090c61e72a42490 http://www.bootmod3.net/log?id=5cccfd6cc090c61e72a4248e http://www.bootmod3.net/log?id=5cccfbc5c090c61e72a4247f please someone take look at these and tell me how they look i know they are not the best pulls but i was honestly afraid lol
bmw m2
05-04-2019, 10:24 AM | #80 | |
Rep 529
Is this a 91 or 93oct ots map? If possible get the best octane gas available and try out the acn91 map.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
05-04-2019, 10:29 AM | #81 | ||
Rep 1,170
And I only pump 91 chevron
bmw m2
05-04-2019, 10:31 AM | #82 | |||
Rep 529
05-04-2019, 11:01 AM | #83 | ||||
Rep 1,170
I'm even starting to panic lol do I even want this car now lol I sent them a email since yesterday but no luck yet Maybe they gave up on my car already lol
bmw m2
05-04-2019, 11:07 AM | #84 | |||||
Rep 529
The timing only looks really bad (as in all negative values - timing be pulled) under wot in the lower rpm range where it makes peak torque. It's not totally out of the ordinary but it certainly isn't good. Might want to consider trying a different gas station and see if that helps. Sorry if I got you really worried for no reason with the afr issue lol my bad dude
05-04-2019, 11:09 AM | #85 | ||||||
Rep 1,170
So I'm kinda like wth Some one else said that my afr was peaking and I'm over boosting in 5th gear and Idk what lol I just re filled up my entire tank with another gas station chevron 91 fuel
bmw m2
05-04-2019, 11:13 AM | #86 | |||||||
Rep 529
05-04-2019, 11:16 AM | #87 | ||||||||
Rep 1,170
So Idk
bmw m2
