05-21-2019, 07:04 AM | #45 | |
Rep 15,858
I believe some of the hesitation a few users find in any AT, with adaptive transmission control, is down to driver inputs. I know we've experienced this in our family, where several of us have been driving the same vehicles with AT. Very different opinion and experience of the same unit, but sitting passenger on occasion, it has been clear it is not the gearbox itself, but how it is driven. Not always the case, there are AT's with issues, but many are fine, if driven with some degree of understanding how AT with adaptive management functions. Many drivers are what I call "on-off" or "digital" drivers, on and off the throttle and brakes. (Not how I was taught to drive, MT or AT). As adaptive management uses throttle and brake evaluation as part of its anticipation of driver intention, hard and/or fast brake and throttle application can give confusing messages, particularly when mixed with coasting. Smooth and speed of application, (both throttle and brakes) has a big part in giving precise command to the transmission management. Some times, all that is needed, is a slight touch of the throttle ahead of any required action, to get a down shift, then the 'box is 'awake' ready to go on further command. I've stated for years, "learn to drive an AT", "experiment", get to know its finer nuances. It is much more capable than many find, just on and off the throttle. Find out how features like gearchange suppression function, and how to over-ride it instantly on command, how to control the degree of engine braking to your demands, etc.. Personally I like to take any AT out into the mountains, learn its capabilities and how to exploit it to advantage. The 8-speed is a brilliant bit of kit, far more capable and controllable than many will ever experience in simple urban driving and negotiating a few roundabouts. |
05-21-2019, 07:15 AM | #46 |
Rep 271
true, £300 isn't cheap. but its a small price to pay to know you are updating the box to be as good as it can be, and as good as it could have been out of the factory. as an engineer, i was somewhat scheptical, until i tried it on a friends flashed 6 speed. i was so impressed with the 6 speed, and the 8 speed was every bit as good. for a car that has a list price of over £50k, i thought that £300 was a small price to pay for the gains. also i am v happy with the fact that the xhp flash will actually compliment and extend the life of the gearbox - one thing it does is 'blip the throttle' after every gearshift, whether up or down (as its a diesel, this is not audible tho). this action puts less strain on the box, as there is less initial inertia as the next gear is selected and engaged, as its already 'on revs / at optimum revs' when the gear is engaged. this creates a more seamless drive when going up or down the gears. in D mode, the gear changes are truly unnoticable, in S mode, the changes are v v barely noticable - much better than standard. i have no affiliation to xhp, i just think a product like this is worth shouting about. believe me, if i was not impressed, i would make my feelings clear.
btw, the car is remapped to 370bhp and 720nm, and the 0-60 time is a verified 3.9 sec without using launch control ! as an engineer, i am sympathetic to the strains that launch control can cause on internal mechanical components, so after testing it a couple of times, no longer use it. actually, zf have incorporated a built in software update to alter the launch control parameters when activated for the 50th time - this lets you still use launch control in the usual manner, but in a slightly subdued fashion (not really noticable, but safer on the longevity of the transmission, as 'dumping' the clutch at considerable revs cant be healthy for even the best box). better than audi, which stops working after 200 activations, and later amg's have a similar count.
Ex S3 & GLA45 AMG ... now 435d F32 coupe
APJ245.00 |
05-21-2019, 07:55 AM | #47 | |
Rep 724
Though problem is don't have an android phone or tablet |
05-21-2019, 08:04 AM | #48 | ||
Rep 8,493
APJ245.00 |
05-21-2019, 09:31 AM | #50 | |
Rep 271
as for no android device, a cheap phone can be bought from ebay, borrow one from a mate, or if you have an apple phone, get the xhp for that device
05-21-2019, 11:48 AM | #51 |
Rep 3,967
05-21-2019, 11:57 AM | #52 | ||
Rep 8,493
05-22-2019, 02:46 AM | #54 |
Rep 8,493
I'd make all the same assumptions as per a remap : probably traceable; would invalidate warranty.
Madlil16.50 |
