05-24-2019, 09:21 AM | #23 | ||
Rep 439
Drives: 2016 M235i Xdrive 8A
My plan was to study the BM3 OTS map and crosswalk the changes I liked back to the MPPK map in the editor. You could in theory eventually evolve the MPPK file to be a variant of the BM3 tune with your own signature on it. This method is how now deceased DJ Avicii developed his signature sound. He said he spent years reverse engineering other people's sound patterns before he ever made music. He also never played any instruments. When he re created them he made his own subtle tweaks and adjustments where he saw fit. Pretty interesting. So I guess lemme make sure I understand, with a spring alone you can only make as much boost as that door will hold until it opens. With the solenoid and computer control it can modulate the door beyond the flat interval of say 10 pounds to 15 like BM3 does? But you are saying to run 18 or 20 is unsafe to this eco system of parts!? How do I safely run more boost with my current hardware, or is that not a possibility.... Thanks for the details man it helps a lot!
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
05-24-2019, 10:35 AM | #24 | ||||
dad bod
387
Rep 382
No problem!
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
05-24-2019, 11:42 AM | #25 | |||||
Rep 439
Then I think I'll be up to speed lol
05-24-2019, 12:26 PM | #26 | |
dad bod
387
Rep 382
More boost isn't necessarily bad -- hence stage 2 or a custom tune. More boost accompanied and controlled by the proper tune, fueling, and mods is fine. Uncontrolled boost is dangerous.
05-25-2019, 03:57 PM | #27 | ||
Rep 439
I've asked this a lot and never gotten a direct answer but it seems like you may actually know- what is the harm of running stage 2 with my factory downpipe? Seems like that would be more boost with more fuel within parameters of OEM hardware, the only thing I could try to reason out would be spool time. It would take longer to hit boost target with factory DP because of restriction and friction?
05-25-2019, 11:59 PM | #28 |
Rep 2,357
Very "interesting" to see that PTF allow 3psi overboost without throttle corrections... Some leeway has definitely been given on the safety compared to the stock map.
(A Dane in China) |
