03-03-2020, 12:45 PM | #1 |
Rep 55
N55 Realistic Maintenance/Potential Problems Schedule
Researched everything from our forums, YouTube and others testimonials for months now. I've jotted down notes and compiled a maintenance schedule for things that could go wrong or need to be replaced on our N55 cars.
To note also, of course these problems might not occur ever with YOUR N55 but I feel like a general reference is well needed. Feel free to add on to this list Potential Problems: Belts, tensioner, pulley, radiator Coolant reservoir Coolant hoses Boost leaks related to charge pipes OFHG leak (Idler pulley/belts afterwards) -With OFHG replacement notes of gasket material getting into ducts causing spun rod bearings Valve cover gasket leak (PCV valve related) Oil pan gasket leak Front main seal leak Water pumps & thermostat ($$$) Vanos/boost solenoids Electronic waste gate / valvetronic Electronic steering rack Fuel injectors ($$$) HPFP/ LPFP ($$) (Older models mostly) Diverter valve Rod bearing failure (rare) Walnut blasting (maintenance 60k+ mi) Vacuum valve/leak (inlet pipe cracks?) Intake inlet pipe Running lean? Hood latch Maintenance Intervals: (In miles) Black stone lab kit (for oil analysis) Trans Oil: 50-60k Sparks: 20-30k Coils: As needed Oil: 5-10k (your own preference) Drive belt kit: 50k Coolant: 15-20k Brake Fluid: 10-15k Diff fluid: 30k Power steering fluid: 20-30k Transfer case: 30-40k (X-Drive models) |
03-08-2020, 11:37 AM | #4 | |
Rep 5,392
Spark Plugs- Stock engine- stock plugs & gap, 60k miles Stage1 tune- stock plugs & gap, 30k miles Stage2 tune (higher boost levels) NGK 97506 plugs gapped at 0.022". Change every 15k-18k miles. Coils- 60k miles Brake Fluid needs to be changed based on time, NOT mileage. You are changing because it picks up moisture over time which can destroy brake components inside the system. Every 2 years for safety. XDrive also has a front differential. It has its own specific fluid that comes in a 0.5 liter bottle. Just get a bottle of BMW label fluid from FCP Euro. Every 30k miles wouldn't hurt. Crankcase Vent Hose- it will appear fine on the outside but the heat and fumes destroy it from the inside. When removed, it will crinkle in your hands. I changed mine at 25k miles. See photos |
juliomadara721.00 Gertsee51.00 |
03-08-2020, 07:43 PM | #5 | |
Rep 10,355
100k miles for ignition coils The gaskets for the valve cover and the OFHG just harden over time and leak. It's a BMW feature. The PCV is integrated into the valve cover so just replace the cover when you do the gasket. However there's a hack repair for the PCV but YMMV. Coolant really is lifetime. Just replace it and some hoses whenever you change out the thermostat/water pump. There's no power steering fluid to change. Injectors, HPFP/LPFP are stout. Just don't tune the shit out of the car.
"Drive more, worry less. "
juliomadara721.00 |
03-09-2020, 07:57 PM | #6 | |
Rep 3,947
I would replace the injectors and HPFP at 100k miles for preventative maintenance. |
03-09-2020, 08:14 PM | #7 |
Rep 1,467
Does anyone think its worth replacing the actual valve cover as well when you do the gasket?
03-09-2020, 08:55 PM | #8 |
Rep 10,355
Yes only because the labor is intensive. You'd hate to spend $600 in labor twice within 15k-20k miles.
03-10-2020, 10:22 AM | #10 |
Rep 3,947
03-10-2020, 04:00 PM | #13 |
Rep 10,256
juliomadara7, nice summary and well done. Connecting rod bearing wear is a rare problem and can be diagnosed by performing oil analysis (metal shavings will be present).
juliomadara721.00 |
03-10-2020, 05:13 PM | #14 |
Rep 558
juliomadara721.00 |
03-10-2020, 06:31 PM | #15 |
Rep 55
I've heard the same and have seen a couple of examples. Seems like the best use out of it is those running tunes etc, although I hear the figment isn't precise. Definitely a good add on for preventative maintenance
03-10-2020, 06:39 PM | #17 | |
Rep 55
Idk most culprits is particles getting in the house, air bubbles, starvation of oil for a second. Hopefully we can get some solid reasoning for it : |
03-22-2020, 04:42 PM | #19 |
Rep 7,607
03-23-2020, 04:19 PM | #20 |
Rep 1,467
just did the valve cover and gasket. Not a terrible job, but it did take me 9 hours in total. I had to replace the PCV hose since it broke. That probably took me an extra hour. I also dropped a tool and fought hard to loosen and tighten one of the bolts. If i could have eliminated the nonsense, id say its a 6 hour job.
03-23-2020, 06:11 PM | #21 | |
Rep 10,355
