09-21-2021, 06:56 AM | #1 |
Rep 25
Dinantronics sport performance tuner - 2011-2019 bmw 2/3/4/5/6/7-series/m2/x1/x3/x4/x
OVERVIEW DINANTRONICS Sport Maximum Gains (N20): Up to 30 HP, 50 lb-ft of torque. DINANTRONICS Sport Maximum Gains (N55): Up to 30 HP, 40 lb-ft of torque. DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in the blink of an eye and yields results you will be sure to feel and enjoy, from the get-go. Coupled with Bluetooth capabilities right out of the box that allows for user-controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace. DINANTRONICS Sport plugs into a single sensor which lends itself to very quick and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app, one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment... or anywhere in between. Regardless of what setting is chosen, there is a power level for everyone. Also within the app, the end-user has access to a live boost monitor which streams boost data in real-time to the phone very similar in appearance to the sport gauges on the iDrive. Not only will you be able to feel the difference but now you can see it as well! Perhaps best of all, the unit automatically detects which engine it is installed upon and loads the appropriate mapping. Effectively making a single unit compatible with an extremely wide range of applications making switching to a new vehicle, sharing with another, or selling the unit a breeze. DINANTRONICS Sport does not carry the factory matching warranty that Dinan is known for. DINANTRONICS Sport's warranty is a 1-year product only warranty that does not cover consequential damages or labor reimbursement. Features: Up to +30 HP and +50 lb-ft (N20), Up to +30 HP and +40 lb-ft (N55) Bluetooth smart (Android and iOS Compatible - Android OS8 "Oreo" not supported) Live boost monitor Multiple power settings to choose from (Sport, Sport+, and Race). Valet / parental control modes (-3 PSI) Quick, easy, and discrete installation Automatically detects engine type and loads appropriate mapping CARB EO submitted and approval is pending. 14 day satisfaction guarantee 1 year product warranty (does not include consequential damages or labor costs) Not compatible with the 2010-11 F07 & F10 535i. The DINANTRONICS Sport App is not compatible with Android OS 8.0 (Oreo). DINANTRONICS Sport is set to the Sport setting out of the box. This can be adjusted via the bluetooth app. https://www.dinancars.com/products/s...arts/D440-0010 |
