11-20-2020, 12:57 AM | #1 |
Rep 277
Adaptive headlight issue
Hello, I have a 2015 335i xdrive m sport with about 44k miles on the dash. I have an issue with the adaptive headlights, or a question about them. I have the dealer sheet and it shows I have the adaptive headlight package, yet when I’m driving I don’t notice the headlight adjusting in any way when turning the wheel or anything. Is there something I have to do for these to work? I have no errors on the I drive system for any lights or anything. I even looked up my vin on mdecoder.com and it shows I have package s524 adaptive headlights. Any help please?
11-20-2020, 07:37 AM | #3 |
Rep 277
Ahh! I knew there was something I wasn’t doing! Thank you, I’ll check to see if that made the difference and report back. And thanks! I love my toys!
11-20-2020, 07:40 AM | #4 |
Rep 923
In my 2016, I believe they only move in the auto position on the light control module, but I also have to press the button on the bottom half of the left turn stalk.
11-21-2020, 08:54 PM | #6 |
Rep 285
Drives: 2016 340i X Drive
The Mulroney for my 2016 has an extra line: adaptive headlights coded off. This was due to US regs. Check your sheet.
11-21-2020, 09:12 PM | #8 |
Rep 285
With the anti glare and variable light distribution coded off they just function as automatic high beams. I took it to a pro to code them on, but he was unsuccessful. When the dealer updated the car’s software last year the anti-glare feature started to work.
11-21-2020, 09:25 PM | #9 |
Rep 1,471
US cars have on or off high beam assist, with coding as you mention they can be adaptive. Mine are coded as remain so even after dealer updates. My point was that normal adaptive functions remain when not using the high beams.
11-24-2020, 03:26 PM | #10 |
Rep 4,420
Drives: '23 X1 28i xDrive
This thread is mixing and matching 3 different features:
-Euro "anti dazzle" -Auto high beams -Adoptive front headlights (swivel) My car has adoptive headlights, which, as noted above, will only swivel if the headlight position is in AUTO. I do not have auto highbeams, which is activated by a button on the turn signal stalk, if you have them. The "anti dazzle" feature isn't available in the US, but some have said can be coded if your car has the right headlight configuration. |
11-24-2020, 04:52 PM | #11 | |
Rep 1,641
tex26702400.50 |
11-24-2020, 08:09 PM | #12 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
To elaborate on the "anti dazzle" functionality (aka non-glare highbeams (NGHB)), in the US market only pre-LCI US adaptive LED headlights have the necessary hardware to support this feature after the proper coding has been done. No other headlights in the US market support NGHB at the hardware level. US market cars have two option codes added to the vehicle order (VO) that disable certain functionality: 5AP disables NGHB, and 8S4 disables variable light distribution (VLD). I won't go into the coding details as this is covered at length elsewhere. Regarding VLD, this functionality enhances adaptive headlights by shaping the light projected based on environmental and speed conditions, IE at low speeds the beam is spread out and shallow, and at higher speeds it narrows and raises up to shine further away. VLD can be enabled on any adaptive headlights, US or otherwise. High-beam assistant (HBA) is required in order to enable NGHB (along with KAFAS2 camera) but otherwise has nothing to do with adaptive/swiveling headlights. With NGHB disabled all it does is automatically turn on/off the highbeams based on the presence of cars in front of you. If you have enabled NGHB, the HBA button is what turns NGHB on/off. Edited to state that in the US only pre-LCI adaptive LED headlights support NGHB at the hardware level, no other headlights in the US support this. Last edited by psyki; 11-25-2020 at 01:41 AM.. |
11-25-2020, 10:22 AM | #13 |
Rep 840
Also, if you have Adaptive Headlights and they are in the ON position, when you start your car they do a quick movement check. You can also, while parked with the Adaptives on, just look at where the lights are aimed and move the wheel to the right and left, the beam should move.
The reason you cannot code in NGBH properly is those lights have additional hardware shutters built in, we don’t have those. |
11-25-2020, 01:10 PM | #14 |
Rep 1,471
01-25-2021, 03:23 PM | #15 | |
Rep 277
If you aint first, your last.
05-09-2021, 04:56 AM | #16 |
Rep 5
high beam asist problem
hello guys. i have o problem with my kafas 2 camera. after the windshield replacement the high-beam assist didn't run as before, the sign recognition ran normaly and when i went to a shop to see what was the deal he found out that it needs to calibrate. i went out for a ride to calibrate the camera and i got a error message about the camera based system and to visit the shop. i did this 2 more times with the same result. now as i'm writing this i realised that the calibrations were done at night. have any of you has the same problem?
08-06-2021, 10:29 PM | #17 |
Rep 420
Drives: 2017 F31 328dx
I have a LCI with adaptive LED headlights. I had VO coded the anti-dazzle and variable light distribution before reading that only the pre-LCI had the hardware in the lights to properly run anti-dazzle. I left them coded and really didn't have a good chance to test the VLD until tonight.
I put on my auto high beams on a back road just to test it out and as I was driving I realized the auto high beams weren't turning off as cars were coming at me and no one was flashing me. When I passed the second batch of cars I noticed that the drivers side high beams were turning off and on and the headlights were shifting as someone approached. As I passed them the high beam would pop back on. I was loving it because I could see so much better on the passenger side of the road. So even though the LCI's don't technically have the anti-dazzle hardware to split the beam, coding for anti-dazzle and VLD will give you a functional high beam option that we are supposed to have with these headlights. |
dmaxdmax416.00 |
08-07-2021, 05:40 AM | #18 | |
Rep 923
08-07-2021, 01:10 PM | #19 | |
Rep 420
Here is a video that will show you how to do the VO coding. If you have the pre-lci there are a couple of videos and threads to do all the extra coding. Search anti-dazzle m4 |
dmaxdmax416.00 |
08-07-2021, 06:09 PM | #20 | |
Rep 923
08-07-2021, 06:20 PM | #22 | ||
Rep 4,537
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh...37&postcount=5 Not sure how well GFHB will work on LCI cars because of the hardware, but the VLD should work just fine. You can also adjust the VLD highway light activation speed. I like 50mph: https://f87.bimmerpost.com/forums/sh...4&postcount=61 Last edited by AndrewC1989; 08-07-2021 at 07:06 PM.. |
