09-20-2018, 09:54 PM | #23 |
Rep 1,934
From what I can see from photos of the turbo, the exhaust housing is integrated into the manifold.
If anyone were to use a larger turbine they'd either have to produce their own manifold, as well. Their other option would be to somehow remove some material off of the inside of the manifold housing the turbine. The latter doesn't look to be easy at all, from either end of the manifold. So, with that, producing a manifold to go with the turbine seems like a more appropriate way to tackle the problem. That then becomes a much larger investment as far as R&D, and will really start cutting into most businesses' margins. If it was one of the M cars that'd be a much different story as far as chances of making a good ROI. No one believes in the f30 market that much, yet. These cars would have to really come down in price to be a safer bet for the market players that are around to really even attempt something like this. And so we are only seeing compressor side upgrades for now.
09-20-2018, 11:28 PM | #24 | |
Rep 1,693
09-20-2018, 11:33 PM | #25 | |
Rep 1,934
What kind of power do you think this smaller stage 2 should make?
09-20-2018, 11:40 PM | #26 |
Rep 1,693
I don't really like comparing turbos by how much power they make if you push them to their absolute limit. I'm in Australia and our dyno numbers are very different but let's just say 430whp on a dynojet, but with less exhaust back pressure, less boost needed to make it, more torque while building boost and more timing possible than existing Stage 1 turbos.
09-20-2018, 11:55 PM | #27 | |
Rep 1,934
09-21-2018, 02:19 AM | #28 | |
Rep 1,348
Similar stuff is coming out for the f80 M3s as well which will rid them of their turbofolds.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 09-21-2018 at 02:33 AM.. |
BMW DIY Guy3068.50 |
09-21-2018, 04:52 AM | #29 | |
Rep 1,693
ceedawg467.50 |
09-21-2018, 09:13 AM | #30 | |
Rep 1,348
09-21-2018, 10:27 AM | #31 | |
Rep 3,016
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
ceedawg467.50 |
09-21-2018, 03:47 PM | #32 |
Rep 1,693
Of course they run better. Their turbine wheel is a little bigger. That's what I want lol. B58 has a Bosch/Mahle turbo. Manifold difference is negligible. It's the bigger turbine and possibly a slightly bigger compressor.
09-21-2018, 06:07 PM | #33 |
Rep 1,348
We agree it is a bigger turbo and from the drawings I've seen the stock B58 turbofold is way way better designed and bigger than the stock N55 turbofold. I saw nothing debatable about that fact. To me it's the whole combo. Bigger turbo and better designed exh manifold . All reducing backpressure.
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 09-21-2018 at 06:15 PM.. |
09-25-2018, 10:08 AM | #34 |
Rep 1,127
Maybe you could just ask Pure to make you a Stage 1.5? I dunno why they wouldn't do it? maybe it's a lot of effort to source and test different parts for a 1.5?
09-28-2018, 08:56 AM | #35 | ||
Rep 886
09-29-2018, 12:32 AM | #37 |
Rep 2,577
OP you made an excellent point. Those here commenting against you, are already the users of PS2, which is a little laggier than many like. I experienced more N55 turbos than the most - PWG, EWG, STG1, STG2 (TTE460, PS2, G Power). I can tell these turbo responds SIGNIFICANTLY different.
The laggiest is of course the PS2 (full spooled at 3k5~4k depending on gear, provided targeting 18psi), which also arguably makes the most power. You're right, people like MOST power. Some of them just don't know what they're missing. Or have a selective memory when they become an owner already. I have the G Power, the best N55 hybrid turbo (in my opinion) that's ever available, yet I admit responsiveness is lost a bit. From log, it's a 300~400rpm delay in full spool on 3rd gear. And it can be felt on the road if you look for it. Yet it's the best mod I've ever had. The logs (same map, same condition, almost back to back) shows PS2 is 500~800 laggier on 3rd gear than my turbo. Which means 800-1000 rpm delay in spool compared to EWG stock. It's a DAY AND NIGHT difference. Depending on traffic situation, many can ignore turbo lag. On track, of course lag is even much less of an issue. But with daily driving, more traffic you have, more critical it is to have less lag. I remember we had this conversation before. You seem to hold strong reservation about "clip" type of turbine, which in my real world experience, isn't bad at all. TTE460 is responsive, so is the G Power of mine. PS2 does go a bit too far and is laggier. For what it costs, TTE460 should be your best option I guarantee your satisfaction.
Lemania 2320
IK6SPEED4487.00 ChrisFulton227.50 |
09-29-2018, 12:06 PM | #38 | |
Rep 244
I'll most likely upgrade to TTE460 next year, hope it rocks |
11-26-2018, 12:34 PM | #39 | |
Rep 10,473
12-08-2018, 10:01 AM | #40 | ||
Rep 529
I am in the same boat as the OP, I don't want/need ps2 but also feel like ps1 is not worth the cost for the minimal gains only between 5500-7000rpm. Surely there must be a better in between solution in the works somewhere
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
12-08-2018, 10:43 AM | #41 | |
Rep 10,473
ceedawg467.50 |
12-09-2018, 03:56 PM | #42 | |
Rep 1,934
$4K?! I suppose it either comes with its own manifold?
12-16-2018, 03:47 PM | #43 |
Rep 1,693
There are turbines that appear to be suitable already out there eg. https://www.ebay.com.au/itm/MAMBA-9-...7/173460084348
Hopefully someone comes to the table with something. I'm still just leaving mine stock at the moment but hating it. |
akgambino271.50 |
12-16-2018, 04:56 PM | #44 | |
Rep 529
