BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Traction Control Light on
      05-01-2021, 08:05 PM   #1
vharish006
Drives: BMW 430Xi
Hi
My Traction Control Light on Showed up today and it slowed the vehicle.I switched it off and drove. .During Regular Service they mentioned my Rear Brake Pads are 4MM and Recommend performing rear brake service with Rotor Replacement.Rotors have excessive Rust on Inner Side Causing poor Pad contact.
Gave me a Quote of $859
Is it the reason for this Light on? Please suggest.
430 Xi GC
      05-01-2021, 09:09 PM   #2
BimR
Drives: 2016 328
I don't know if that's the cause for the error (doubt it) but that's not terrible of a price for brakes. And you should get those fixed if they are at 4mm.
      05-02-2021, 03:07 AM   #3
HarryTee
HarryTee's Avatar
Drives: 2018 M4CP & 2017 440i GC
"My Traction Control Light on Showed up today and it slowed the vehicle.I switched it off and drove. "
That was what happened to me (many years ago) when the ABS sensor needed replacing. I don't know if it still works this way nowadays (I haven't had ABS sensors problems with my recent cars). After you've had your brake work done, if the light is still on, then look into this possibility.
      05-02-2021, 11:48 AM   #4
CajunBMW
CajunBMW's Avatar
Drives: BMW 340i and X1, Chrysler Van
I think I had the same issue as I recall with my old e46. In my case the computer controlling that process went bad. It was an expensive fix, if we are talking the same thing. Good luck.
      05-02-2021, 12:19 PM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Get a second opinion. A ridge of rust on the outer edge of rotors is normal, and is easily removed. It takes a lot more than that to require replacing rotors. It shouldn't have anything to do with traction control. You may have even turned the light on inadvertently.
      05-02-2021, 12:31 PM   #6
HarryTee
HarryTee's Avatar
If you turned the traction control light on, I don't think that would slow the car down as the OP reported.
      05-04-2021, 04:59 PM   #7
jmg
jmg's Avatar
Drives: F80 M3 CS, i3 LCI, VW Atlas
Traction control uses the brakes to correct yaw. It could be related, although I would think the brake warning would go off first.
OP: Traction control will also cut power along with apply brakes to wheels that have lost traction, but that loss should go away as soon as your car regains composure. Was it a permanent power loss, or momentary? The traction control light that went on, was it a WARNING light or a light that says you turned if on/off?
2018 F80 ///M3 CS - Lime Rock Grey Metallic | MPE | MPHAS | GC Camber Plates | PFC-08 | RE-71R
2019 I01 i3 BEV - Giga World
2021.5 VW Atlas 3.6L V6 SEL 4Motion
Previous: F80 M3 | I01 i3 Rex LCI | I01 i3 REx | F30 340i M Sport ZTR | F30 328i Sport | Audi B7 S4 25Quattro #33 of 250 | E21 320i
tires, traction control
