05-07-2021, 04:00 PM | #23 |
Rep 51
Please be careful with glue - I know a couple guys using glue inside there headlights caused damage. As the glue heats up it creates fumes that then can damage/haze the plastic lens and/or reflector.
07-26-2021, 08:30 AM | #24 | |
Rep 15
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
sspade2464.50 |
07-26-2021, 09:20 PM | #25 | |
Rep 192
I only tried once and didn't spend a whole lot of time but I couldn't finesse them in with those adapters either I didn't remove the wheels which probably would be easier but the other issue I ran into is the LCI halogens have this weird flange type thing that the tip of the halogen bulbs fits right into and the LED's I got (auxbeam) wouldn't fit into this flange so I bent it a little, luckily I got the halogen bulb back in there but if you look up close from the outside of the headlight you can see where I bent it some Why would BMW ever do such pathetic headlights is beyond me - I get it that it's all about money, but good grief Worse case is they should make it much easier to even just change a dang light bulb even if you're stuck with halogens - they don't make changing them easy at all...smh If I'm going to go through all the trouble of having to take the wheels off and spend a ton of time just trying to get an LED in there, I may as well just get better headlights for all that trouble Sure, the light output may be better even IF I'm able to get LED's in there, but changing them in the future will be no bargain and they're still just going to be crappy looking halogen housings from the outside Oh well.....I'm now in the mindset of just not caring anymore about the headlights They are what they are - so, I can spend $2K to get something legit or I can just stop worrying about it and spend the $2K on something else lol |
phabmasta6.00 |
08-02-2021, 02:05 PM | #26 |
Rep 5
Good thread - so what lamps are people buying now?
The Amazon ones linked are not currently available - Aukee H7 LED Bulbs, 50W 6000K 10000 Lumens Extremely Bright CSP Chips Conversion Kit Replacement Low Fog Light |
08-02-2021, 05:16 PM | #27 |
Rep 5,456
Drives: F30
I want someone to prove with pics that LED bulbs can be installed on an LCI F30 with halogens.
We know that the pre-LCI housings are easy to swap LED's into (done it personally) but had difficulty when trying on my LCI. The housings are DEFINITELY different than my prior F30. |
08-03-2021, 08:30 AM | #28 | |
Rep 15
08-03-2021, 08:33 AM | #29 | |
Rep 15
sspade2464.50 |
08-03-2021, 09:37 AM | #30 | |
Rep 5,456
Drives: F30
https://www.theretrofitsource.com/h7...APT?quantity=1 |
08-03-2021, 02:20 PM | #31 | |
Rep 15
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and these adapters: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 As I mentioned before it was a pain to get the bulb and adapter to sit. The color on the bulbs is not nearly as blue as pic shows, phone just cant handle it. Hope this helps. |
sspade2464.50 |
08-03-2021, 02:28 PM | #32 |
Rep 5,456
Drives: F30
Thanks man, very much appreciated. The adapters that you used look similar to the ones I have... which leads me to believe that the Morimoto bulbs were the issue.
Still have the adapters, will have to try a slimmer bulb body like the one you linked. |
08-14-2021, 11:09 PM | #34 | |
Rep 312
I'm looking at the Morimotos as well..not sure about the Amazon offerings being so cheap. |
08-15-2021, 08:10 AM | #35 |
Rep 16,079
The Amazon offerings come from China. So do Morimotos and Weisslicht, despite what their names imply. For a successful result ignore the advertising and use what someone else has used and recommends.
I didn't use adapters. I did secure them with high temp RTV, as the stock mounting clip wasn't designed to hand the weight of an LED. https://f30.bimmerpost.com/forums/sh....php?t=1377259 |
boyerizm243.00 |
08-15-2021, 02:44 PM | #36 | |
Rep 312
Man, I'm not sure I want to dremel the housing though :/ |
08-15-2021, 05:21 PM | #37 |
Rep 16,079
Worried about your warranty? After wasting a couple of hours trying to work through the wheel wells with the wheels off and the fender liners removed I finally did what BMW should have done in the first place and put access covers on the top of the low beam housings. After doing that installing the bulbs took all of fifteen minutes.
08-18-2021, 11:35 PM | #38 | |
Rep 312
I was debating actually removing the assembly and doing a projector retrofit. But this looks like it would be a royal pain in the ass to do well. Most likely I'll follow your advice and just dremel in access. Thx again |
02-17-2022, 02:10 PM | #40 | |
Rep 51
Amazon Link: https://amzn.to/3sJg2BW and they worked very well. On to an X5 for me - Halogen reflectors are not an option for me anymore. GL with your headlights all! |
08-30-2022, 11:25 AM | #41 |
Rep 51
Thread revival
Posted a video on this topic for those still working out issues with their headlights will update original post with video as well Good luck everyone |
09-24-2023, 11:10 PM | #42 |
Rep 51
09-25-2023, 11:36 AM | #43 |
Rep 16,079
I can't recommend fan cooled LEDs. It's a weak point in their design. Besides, you don't need the super high output of LEDs that require fans. You might not want it either, if you get pulled over for having headlights that are too bright.
09-26-2023, 03:12 AM | #44 |
Rep 159
Passive cooled LED bulbs barely get any brighter than original halogens. Fans don't just simply break down, at least not if you buy from a reputable brand (Phillps/Osram).
If possible i'd suggest just fully replace the headlight with some plug&play solutions like from the newer full LED HL from Depo or Aokeding. You'll get a proper beam pattern and overall much better brightness and in theory longer lasting life. I've had bright LEDs bulbs that never lasted more than a year. |
