05-13-2021, 05:31 PM | #1 |
Rep 266
Rear left window problems
Hey guys,
I tried to roll my rear passenger side window down today and it would only go down/up in really small increments, like less than an inch. It was working fine not too long ago (I don't roll that window down very often). All other windows are working normally. Anyone had a similar issue or know what the cause could be? Thanks,
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
05-15-2021, 02:04 AM | #2 |
Rep 2,015
Does it go up/down properly with rear door window control?
If so, then your front door switch or wiring is messes up. If rear door switch operated the same.....incrementally then it's either wiring at motor or something else. |
05-15-2021, 08:35 AM | #3 |
Rep 455
Have you tried learning the end stops? Open it fully and then keep the button pressed at the second detent for a few seconds. Close it fully, keep the button pulled for a few seconds.
Let us know how it goes. |
