BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Chevron Techron Fuel System Cleaner- The most amazing thing ever
      11-21-2018, 07:24 PM   #45
Mr Podman
Drives: 3 Series GT Stage 0.5
We call it monkey milk.
You're wasting your money.
podman
      11-21-2018, 10:46 PM   #46
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Originally Posted by Bestodabest View Post
Your 525 isn't direct injected, so yes your intake valves would be exposed to the fuel-injected cleaning agent. You wouldn't see this benefit with the direct-injected N54/N55.
+1. Techron is probably effective in cleaning the fuel delivery system from the tank to the injectors but it doesn't clean the intake valves with direct injection engines. That requires intake valve cleaner.
      11-22-2018, 12:11 AM   #47
BMWILUVU
Drives: 340ix
Techron works yet also leaves deposits on the cylinder head too.
      11-28-2018, 10:03 AM   #48
IraHayes
Drives: 635csi
Techron is legit. I noticed a huge difference when I used it on my old Jeep, and also noticed an increase in mileage when I switched to Chevron gas in all our cars. While itís true that the valves in our DI engines wonít reap the benefit of fuel system cleaners like Techron for cleaning the valves, donít forget that piston tops develop carbon buildup too, so Techron can still help in that regard; not to mention helping keep injectors clean as well.
So far as valves go, walnut blasting seems to be the primary solution. I do plan to use that CRC GDI cleaner before my next oil change. I have an endoscope and will try to take some before and after pics when I do. Iím really curious to see if that stuff works. If it does, it can save us a lot of hasssle.
sspade1499.50
      11-28-2018, 10:22 AM   #49
pongkin
Drives: f30
how is this compared to liquimoly jectron?
      11-28-2018, 10:40 AM   #50
Billfitz
Billfitz's Avatar
Check the ingredients on the labels.
      11-28-2018, 01:04 PM   #51
sspade
sspade's Avatar
2014 BMW 328i  [5.00]
FWIW...
I user a bottle of Techron on my last fill up before oil change (every 5k).
No issues, car runs like an absolute top.
BMW 328i FBO, Bootmod3 Stage 1
      12-06-2018, 01:57 PM   #52
X2 Monstah
X2 Monstah's Avatar
Drives: 2018 X2 XDrive 28i M Sport
I put a bottle of Techron in my 328 and my wife's 128 this past weekend. I noticed a considerable improvement in the 328's throttle response and it seems the injectors are much quieter also. The 128i seems to run smoother, but that is a silky-smooth, easy-revving car anyway. Haven't noticed any change in MPG yet, but I'll be watching it over the next few fill-ups.
Mine: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather (Okay, the wife assumes it is her's)
Wife's: 2011 128i / Jet Black / Black Boston Leather
Previous: 2008 E92; 2014 F30; 2016 F30 M Sport
      06-28-2019, 09:21 AM   #53
Wolfus Aurelius
Wolfus Aurelius's Avatar
115
Drives: 2015 BMW 328i (gold/cream)
Originally Posted by thumperwhite View Post
FWIW, Techtron is well know amongst the 'air cooled' Porsche club. Common process is to add Techtron to a full tank, burn through the tank, then change the oil. I'm told the reason to do this is because Techtron can seep around the piston rings and stay resident in the oil. There is a concern it adds wear to the oil pump.
That's my understanding too. I'm about to add a bottle of the Techron to my tank, run about 700 miles (several tanks' worth, of course), and then do the 30K mile oil change. After that, every 5000 miles for both.
      09-07-2019, 01:44 AM   #54
Onizukachan
Great Teacher
Onizukachan's Avatar
Drives: E46/3 M56 & F31d
its the ONLY thing that can clean the deposits off an e46 SULEV fuel sender (the tanks are 100% sealed, so fixing a non working fuel level sender or pump means an 8K tank plus labor) and restore it to operation. When mine gets wonky (we only have shell stations), i add TWO bottles, fill the tank and let it sit over the weekend, invariably the level starts working again on monday. when i first bought it i had to do this two tanks in a row, but it works now and works reliably for 10-12 months before i have to do it again.
      09-18-2019, 06:43 PM   #55
Zanity
Zanity's Avatar
Drives: F32
I been using only chevron 94 octane with 0% ethanol, so I get a good dose of the techron addictive with every fill up. Always ran fine, instead of buying techron separately, why don't you just get chevron 94 gas ? It comes with techron generously added already. From what I read, it's better to do it this way because you are cleaning it long term rather than just cleaning it once with a bottle then starts the buildup again. Also, ethanol is extremely bad for our cars, in case somebody reading this but doesn't know.
4 wheel moves the car, 2 wheel moves the soul.
      09-28-2019, 11:39 AM   #56
IraHayes
Drives: 635csi
Where are you finding 94 octane Chevron? I want some too!
      10-01-2019, 02:31 PM   #57
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
I can only dream of ethanol free 94 octane gas. Around here 93 is easy to find, but I believe state law requires ethanol blends. The nearest ethanol free gas station I know of is 400 miles and two states away.
      10-01-2019, 04:56 PM   #58
Billfitz
Billfitz's Avatar
Try marinas. I don't know about 94 octane but most marinas have ethanol free gas, as too many boats can't use even E10.
      10-02-2019, 09:16 PM   #59
John in VA
Drives: 2015 228i M Sport
Welcome to the definitive list of stations that sell pure, ethanol-free gasoline in the U.S. and Canada! https://www.pure-gas.org/
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system
      10-04-2019, 06:09 PM   #60
Zanity
Zanity's Avatar
Drives: F32
Well, I got a Chevron station a block from my house, I'm in Vancouver BC, but I see you're in cali, so I have no idea
chevron, fuel consumption, fuel injectors, fuel system cleaner, techron
