BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Stock Supra Keeping up with 440i Stage 2
      10-07-2019, 03:14 AM   #23
IMS-340MP
IMS-340MP's Avatar
Egypt
138
Drives: 2018 340i MPPSK
How did you learn tuning your car ? which program are you using ?
Originally Posted by enemigo13 View Post
tuned myself. no dyno, but probably ~420 crank hp
      10-07-2019, 10:37 AM   #24
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
slope, temperature, DA?
Temps was about 60F, slope was 0.10 and DA was around 200
      10-07-2019, 10:44 AM   #25
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Tuned M240i makes no more power than a tuned 340i, 440i, etc. They run faster times because they are lighter and more aerodynamic. They have smaller brakes, smaller/thinner wheels, smaller gas tanks, less potential options/electronics, etc. etc. That's why all of the tuners use m140i/m240i for their development and record-setting vehicles.
Regarding the race with the supra, the 440i is heavier, on some gaudy 20" wheels, also less aerodynamic, and less aggressive gearing than the supra.
And the usual reminder that the aggresive BM3 tune only makes your burbles louder. It doesn't make the car faster.
Instagram @kern417
      10-07-2019, 10:45 AM   #26
enemigo13
Drives: F30 340xi
well, that's disappointing, all stock b58 (except tune) is faster in the same F30 xdrive body than FBO n55 + PS2 with stock hpfp. PS2 probably needs xdi60 to utilize it's potential fully.
      10-07-2019, 10:56 AM   #27
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Well I'm not surprised, stock b58 puts down 330whp stock.
My Ps2 on stock tune puts down 330whp stock tune.
I'm also PWG so I make about 20-30whp less than ewg does.
I'm also only using 91 octane only, so as you can see, I have no access to e85 and closest 93 pump is 3 hours away.
      10-07-2019, 01:02 PM   #28
enemigo13
Drives: F30 340xi
e85 mix would crash your hpfp immediatly. PS2 is way bigger turbo than stock b58 one, and I dont know why ewg ps2 should do more power than pwg one. now you’re limited on hpfp, and probably you run max 1.15-1.2 bar at high rpms to not crash hpfp? ps2 can do 1.5 bar up to redline easily, just xdi pump needed
      10-07-2019, 07:46 PM   #29
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
EWG is easier to tune, PWG sucks to tune lol power comes from the waste gate shutting quicker or with more force or something, not sure why it makes more Power but it does.
PWG can mix up to E40, EWG up to E30.
      10-07-2019, 09:01 PM   #30
IssaF32
IssaF32's Avatar
Drives: 2014 428xi Coupe
Damn my 428 on stock turbo puts down 330. Is your car okay? 🤕🤒
      10-07-2019, 09:03 PM   #31
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Originally Posted by IssaF32 View Post
Damn my 428 on stock turbo puts down 330. Is your car okay? ����
Read again lol
I said it puts down 330whp on stock tune
It was the baseline before I actually flashed a OTS map.
meaning it's on the stock MPPK factory tune the car came with.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, Turbosmart VR9 BOV, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
eluded2439.50
      10-08-2019, 02:18 AM   #32
enemigo13
Drives: F30 340xi
e30 or e40 depending on boost (load) not on pwg or ewg. This stupid myth that pwg has better holding hpfp came from times where ewg stock turbo crashed hpfp easily while pwg stock turbo could not do it. just simply pwg stock crap turbo can do max 0.7-0.8 bar at 6000rpm while ewg turbo can do 1.2 bar there easily. both hpfp units are _the_same_part_number_. So adding ps2 to pwg engine and turning up the boost it will crash hpfp easily on pump petrol only, not talking about E mixes.
      10-08-2019, 03:56 AM   #33
IMS-340MP
IMS-340MP's Avatar
Egypt
138
I agree the Supra has higher 1st, 2nd, and 3rd gear ratios and also higher final driver ratio, but it's real life numbers that counts.
All the videos I saw stock Supra traps 108-110 mph in the quarter, surely decatted stage 2 340/440 trap higher.
      10-08-2019, 06:06 AM   #34
kern417
Cheapskate
You say "surely" but the info is out there.
Here's a guy on meth that only managed a 113 mph https://f30.bimmerpost.com/forums/sh....php?t=1633645
Meanwhile there are supras in the A90 drag group on facebook that trap 114-115. It just depends.
And at the end of the day, that 4 series is not doing itself any favors in the speed department. He clearly built it to be flashy.
Instagram @kern417
      10-24-2019, 10:35 PM   #35
F82Tazmanian
F82Tazmanian's Avatar
Brunei
66
Drives: F80 M3
The most consistent thing I can think of is caranddriver testing the Supra at 113 and a 440i at 109. Not considering any weight, gearing, blah blah, I agree that a stage 2 catless 440i should wipe the floor with a stock Supra. You're adding easily 8-10mph to a stock 440i which should sit at 118-120.
Again this is just what makes sense in paper but I think the stage 2 tunes need more track time. There was a user who did 118 FBO 340i BM3 I believe. That should pull a stock Supra reasonably.
Pending F82 M4 or X4M, 17 340i MPPSK, 14 335i PPK, 13 335is, 12 M3, 09 X6 50i, 07 335i, 04 350z, 08 Si
      10-25-2019, 06:00 AM   #36
kern417
Cheapskate
because roll racing does not translate to quarter mile times/speeds. you can beat someone in the 1/8th and lose to them in the quarter. roll racing depends on where the speed is made and weight has a much more significant advantage.
ask that 440i what it traps in the quarter and i'll bet it's lower than you think.
Instagram @kern417
      10-25-2019, 11:29 AM   #37
F82Tazmanian
Brunei
66
Drives: F80 M3
I agree we won't know until we see some more roll races. I've seen completely different outcomes personally based on who hits first as well. For example my old JB4 328i pulled a n55 535i very easily but next run he got a good jump and I couldn't reel him in.
Another example, I got a very good jump with a Range Rover supercharged that traps 109 in a stock 528xi n20 and he couldn't catch me. Ideal conditions he'd kill me no question. So many factors.
See below: https://f30.bimmerpost.com/forums/sh....php?t=1615232
User beat out a v8 camaro and traped ~118mph on MP stage 2. Maybe the supra would pull on a roll but I find that hard to believe if this 340i pulled a camaro ss.
A lighter M240:
He wrote he has trapped 118 with this set up.
      10-25-2019, 01:41 PM   #38
bimmer456
Drives: 340i
That exhaust system and even the MPE which is just a slightly modified muffler look very basic compared to the mppsk which had two valves. When both are closed one side is closed completely while the other side forces the exhaust gas through the muffler. When both are open it is straight pipe on both sides making it much louder. https://images.app.goo.gl/Q7gRqboH7ceRtbDx7
      10-25-2019, 02:34 PM   #39
kern417
Cheapskate
A lighter M240:
I mean, at the end of the day we both saw the same video. What happened, happened I've pulled on cars that didn't have appropriate gearing for the roll we did many times. I've pulled on cars that were faster, but they had big wheels and tires that dragged it down. there are a lot of things that can have an effect but it's no way impossible. who knows, the car could be a debadged x-drive. there's another 100lbs. It is what it is.
Instagram @kern417
      10-25-2019, 03:48 PM   #40
F82Tazmanian
Brunei
66
Drives: F80 M3
A lighter M240:
True. Just one video
      10-28-2019, 06:47 AM   #41
IMS-340MP
IMS-340MP's Avatar
Egypt
138
With average conditions my 340i with only MPPSK traps 112 mph on 88 octane.
Decatted stage 2 running on decent fuel should have around 100 HP above my car.
2018 LCI 340i MPPSK Catless AT RWD - M Sport Shadow Edition
Fuel: 92 RON - Self Tuned - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2
      10-28-2019, 09:58 AM   #42
kern417
Cheapskate
You're right. I guess the video is fake then.
Instagram @kern417
      10-28-2019, 12:06 PM   #43
IMS-340MP
IMS-340MP's Avatar
Egypt
138
So I guess anybody who proves you wrong is fake!!
Everybody knows a properly tuned 340/440 on good fuel traps around 118 mph.
      10-28-2019, 12:56 PM   #44
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
Properly tuned lol
90% of people use OTS maps or JB4.
340/440i will not trap 118mph without meth also.
M240i will, but not the 340/440i.
Also you have DA, temp changes in most places as well. If it's consistently lower than 80F where you live with low DA, then yeah you'll run faster times with higher trap, but the avg places have high DA with temps ranging from 80-95F.
A FBO 340/440i on both mhd/BM3 here on 93 Oct have trapped a max of 114mph here where I live, temps were around 80-85F area at night.
2013 335i xDrive
kern4173137.00
