BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 269 wheels on an f32 x drive
      10-13-2019, 02:04 PM   #1
human compass
Drives: 2015 428i m sport
Hello all,
I have a chance to buy these for my 2015 428i xdrive and want to see if the offset and diameters will work without rubbing or AWD damage. thank so much!
Style 269 performance wheels
Wheels: StaggeredSet Up
Fronts 8 x 19 et37
Rears 9 x 19 et39
Tires: Bridgestone Potenza RE050A Run Flats
Fronts 225/35/19
Rears 255/30/19
      10-14-2019, 03:20 AM   #2
alohasurftoad
Drives: 428i gran coupe
it will fit without rubbing and will not cause issues to the x-drive transfer case, however the tire diameters are too small causing large fenderwell gap, speedo will indicate higher than actual and odometer will accrue more mileage than actually travelled.
225/40/19, 255/35/19 is oem staggered tire sizes for F3/4-series
      10-15-2019, 01:55 PM   #3
human compass
awesome. thanks so much!
      10-18-2019, 01:34 PM   #4
human compass
picked them up. planning on black powder coat with replacement stock size tires going on.
questions
1. any recommendations for spacers to have them sit more flush?
2. the stock rears are supposed to be 8.5 inches wide, these are 9. will there be any noticeable stretch/decrease in diameter of the tire? If so, any recommendation on different size to decrease gap and not screw up x drive?
thanks!
      10-18-2019, 02:31 PM   #5
alohasurftoad
if you're asking about a different tire size combination 235/40/19, 265/35/19 will help reduce the wheel gap.
figure out your spacer afterwards by measuring the distance from the upper tire shoulder to a vertical line from the fender edge to the ground. the distance will be what thickness of spacer you need.
fyi while spacers look nice, widening both front and rear track widths does not necessarily equate to better handling because increasing the rear track width will increase understeer, increasing front track width with spacer or lower wheel offset changes the front suspension geometry scrub radius. damper and spring rates are also affected as well as turning radius.
      10-18-2019, 03:58 PM   #6
human compass
Mostly just concerned that the stock diameter/width rear tire will be a bit too small stretched onto a 9" wide rim when that size is meant for an 8.5. Dont want to go super beefy but want to keep the aspect ratio under 1% difference if that makes sense.
will do on the spacers. makes sense.
thanks for all your great advice
      10-25-2019, 07:10 PM   #7
human compass
final product
Kingpin4138.00
      10-28-2019, 07:43 AM   #8
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
those poor wheels.. i would have kept them machined/silver. Now they just look like any other black blob of a wheel going down the road.
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      10-28-2019, 12:24 PM   #9
human compass
I was on the fence but they had a fair bit of curb rash and i live in a small town with no wheel refinisher so powder coat was my only option. fortunately i quite like how they turned out.
