BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F30 Android Avin 10.25 rear camera install
      10-04-2017, 10:20 AM   #23
BMW DIY Guy
Drives: 2014 435i
2014 BMW 435i  [0.00]
Originally Posted by Chanrith View Post
Hello,
I'm new to this forum but I recently purchased a 2013 320i xDrive. I'm trying to add a no-name aftermarket OEM integrated backup camera and am having some trouble figuring out how to power up the camera. I have a red and black wire and am looking to connect it to the right side reverse light but am not sure which wires to splice and I'm not sure it will be enough power to power up the camera.
I've attached a photo of a similar camera that I'm working with.
Any advice appreciated. Thanks!
--Chanrith
Happy to help if I can. Look for the two wires going to your backup light, usually on the passenger side. There should be brown (ground) and red, or black with a red stripe, or a couple of other options. Brown is ground.. so tap your black to the brown ground, and the red to the other.
Check out my BMW DIY Channel on YouTube! F32, F80, E39, E46, E53, and E83 projects from Active Autowerke, TuningTechFS, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** ** Facebook BMW DIY Guy **
'Furiosa' F32 Build Thread
      10-04-2017, 05:59 PM   #24
Chanrith
Noob
Chanrith's Avatar
Drives: 2013 320i xDrive
Awesome, I will try it out. Attached is an image of the connector for the right rear taillight. I've found brown, now gotta figure out where red goes as I only need the camera to turn on when in reverse. Thanks so much for your help with this.
Green #1 = ?
Brown #2 = Ground
Yellow #3 = ?
Blue #4 = ?
      10-04-2017, 09:26 PM   #25
philb1972
Drives: BMW 320d F30 Auto Sedan MY13
Hi,
Can you repost the pictures in the first post? All I can see is a place holder "Photobucket please update your account....." (or am I doing something wrong?)
Also can you confirm there is no coding (I am wondering why that is)?
Thanks,
Phil
      12-07-2017, 11:56 PM   #26
skoold2003
skoold2003's Avatar
Drives: 2014 X5 50i M Sport, M3(sold)
Hello,
--Chanrith
I don't know why everyone is saying to use the backup light for this. Initially I tapped my light and tried to run the cam directly from it. This doesn't supply enough current to run the camera directly.. maybe earlier posters were suggesting to use it as the trigger for the relay? Ultimately I ended up testing the cam wire coming from my avin unit (purchased three weeks ago) and it works just fine. Just connect the red wire on the power cord to the red wire from the head unit and the black wire to a chassis ground.
      01-10-2018, 05:14 PM   #27
KevDon92
Drives: 2014 435i
Do I connect the red wire to the AVIN Camera +12V wire or the Camera Detect wire?
      01-11-2018, 03:38 AM   #28
a803sgo
Drives: BMW 320D M-SPORT (F30)
12v
      01-11-2018, 03:48 PM   #29
BMW DIY Guy
Drives: 2014 435i
Photos are busted.. can you update so they can be visible again? Thanks!
      03-31-2018, 06:19 PM   #30
BCBMWF30
BCBMWF30's Avatar
      04-06-2018, 09:46 PM   #31
xl3vax
Drives: 428i BMW
AVIN rear camera
When you turn the steering wheel, do the green and red lines on the screen curve accordingly or are they static?
In my screen they stay still... what do I need to do to make them connected to the steering wheel?
I just finished installing my gen2 10.25 screen and I connected the camera:
I just connected the red cable REAR CAMERA from the screen and the RCA yellow from the screen to the camera wire. It works.
      04-20-2018, 08:17 AM   #32
Pacsniper
Drives: 2013 328i Sedan
Looking for any form of help to install the Backup camera. If only the pictures were still there
      10-15-2018, 06:43 PM   #33
mynameisname
mynameisname's Avatar
Drives: Glacier Silver 328i
I got the wireless 2.4ghz camera with transmitters. I don't know which wire in the car's harness is for the reverse camera. The video cable that I was provided with the camera has a blue wire that needs to tap into the reverse camera wire in the car. Anyone know where this is (what color)?
      12-28-2018, 12:28 PM   #34
Atibbs2009
Drives: Bmw 328i f30
WiFi transmitter
I bought the WiFi transmitter as well did you figure out what wire it is
      01-03-2019, 10:13 AM   #35
mynameisname
just decided to hardwire it and run the wires through. instructions were really lacking clarity
      10-20-2019, 07:20 PM   #36
richard_yii
Drives: BMW 3 SERIES 320D
Can someone help me please. I bought the after market reverse camera and connected it.
In the image you will see the 2 red wires, that's the camera wire connected to the 12V reverse camera light. I used a DIGITAL MULTIMETER to find out the correct wire.
However when I put the car in reverse. The camera connections is very very temperamental, its comes on for about 2 seconds and then goes off. I believe the camera is not getting enough power to it. How did people fix this is this?
I have this little box, I believe it's a relay box, However I have no idea on how to use it.
This image is my reverse camera with all the wires. The only thing missing is the relay.
Pictures and links will be useful please. Thanks
      10-23-2019, 01:06 AM   #37
Mirjam
Drives: BMW E87, F10, i3
The easiest way to connect a third party backup camera to an Android unit:
1. Connect the yellow video cable to the Android box, and to the camera in the other end.
2. Connect the red wire sticking out from the video cable, to the red Camera (+12v) wire on the Android unit, and the other end to the red camera power cable.
This is usually all it takes. Ground is supplied through the video cable.
Now, if this doesn't work, then you could try this: Ground the black cable from the camera power harness.
If still no success, you might need to use the Detect (DET) wire from the Android box: Find the +12v cable in the backup light harness, and run a cable from it to the Detect wire. In this last case, there might not be any power from the Android Camera +12v cable either, so you will need to find another power source. Only in this case is a relay needed.
      10-23-2019, 01:18 PM   #38
innovaciones
Drives: BMW F32 428i M-Sport
Pretty much this is the way to connect it on 99% of Android units including CarPlay boxes, now I made a pretty rough diagram using the picture posted to explain how everything should be connected.
      01-06-2020, 09:35 AM   #39
ozumct
ozumct's Avatar
Denmark
Drives: 2017 BMW 420d Gran Coupé (F36)
Where to find the +12v power supply for reverse light on BMW F36?
