BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Experience with 10.25" android 7.1 HU's
      09-27-2019, 12:47 PM   #2795
TooYoungForMerc
TooYoungForMerc's Avatar
Finland
Drives: F30 and G30
Is there ID7 firmware available for these px3 7.1 units?
      09-29-2019, 06:52 AM   #2796
Evano
Drives: M240i
I installed reverse camera & it works perfectly but was wondering if it's possible to have it activate while driving forward in dvr mode?
Also interested in ID7 firmware update for 7.1 units if anyone has link or managed to do this?
      09-30-2019, 11:26 AM   #2797
Pondaire
Drives: 2013 328i
It depends on how you wired it. If it's wired through the backup camera 12V wire from the headunit, you won't be able to. This headunit only kicks in the 12V when your backup gear is engaged.
If you have it as always on through some other 12V wire, this is feasible.
      10-01-2019, 08:11 AM   #2798
dodgePT
dodgePT's Avatar
Drives: BMW F20 2013
Hi guys, great info in here!
I've ordered one of these android units (the so called PX6) for my 2013 F20 to upgrade the WinCE one I installed five years ago. Yeah, I'm one of those lucky guys without iDrive...
Fortunately these units work perfectly on a non-iDrive BMW, the thing is, the chinese don't make the "pseudo-iDrive-controller" for my head unit, only for X1 and other older models.
They told me they thought all F20s had iDrive.
So I was thinking, the unit I ordered must be a "NBT" unit, since I believe BMW went from CIC to NBT around 2012, is that correct?
The iDrive controller is just another device on the CAN network, so what would happen if I bought an used iDrive controller, fed it 12v from the lighter nearby and then tapped the CAN-H and CAN-L on the radio harness.
Do you think the chinese HU would detect the controller signals?
Thanks for your help, cheers!
      10-02-2019, 10:11 AM   #2799
pitoncho
Drives: bmw e87
Hello guys!
I have an 10,25 screen by fltombo bought in aliexpres... my car is an e87 series 1.
the question that i have is that i have bought an idrive controller for retrofiting it in my car, but i dont have the conecctions to the car.. i would like if someone can explain me how can I connect the idrive controller (ccc) to the screen radio.. i didnt find anything in internet.. thank you!
      10-04-2019, 06:22 PM   #2800
Mirjam
Drives: BMW E87, F10, i3
I think you need the iDrive controller that you can buy with the Android units. Contact the seller and ask for such an iDrive controller.
You can not connect an original iDrive controller. Cars with original iDrive have a different Head Unit, which the Android unit connects to. It will be far too much job retrofitting CCC or CIC for this.
      10-05-2019, 10:34 AM   #2801
pitoncho
Drives: bmw e87
So, i need to leave the idea of make it work the ccc original with the android screen? Ive seen in other places that this screen can be used with the original ccc..
And other question, how can i install an update? ive done all the steps with the usb but i cannot do anything.. i want to have the chinese idrive cotroller working with android auto app.. Thank you!
      10-05-2019, 02:42 PM   #2802
Pondaire
Drives: 2013 328i
Originally Posted by Kri View Post
You can also extract the Launcher from your OTA file, i just added an Android 9 Extractor batch to the URTOOL at Github.
Do we have anywhere a compilation of the sources for the modified apps? I found in the github page the modified firmwares and stuff, but I was not able to find the specific code changes in these apps/firmwares. I'd like to modify mine :/
      10-05-2019, 10:44 PM   #2803
Mirjam
Your car doesn't have CCC, as I understand you. In that case you will have to replace your Head Unit with a CCC unit if you want the original iDrive controller. A better solution for you is to buy the iDrive controller that is supplied with some Android units. Check the harness from the Android unit, is there a cable labeled X1? This is for connecting this (not BMW original) iDrive controller.
      10-06-2019, 04:19 AM   #2804
Kri
Austria
524
Drives: E87
I also don`t have information to modified code yet, i`m no programmer i`m only analyzing the code between version to see what had been changed/updated.
Chri
      10-13-2019, 05:51 AM   #2805
adrian.k
Drives: 2007 e93 325i se
Has anyone managed to change the boot animation on these units to a custom one yet?
      10-15-2019, 02:58 AM   #2806
irose50
Drives: BMW X4
Head Unit Reloaded
Does anyone here use these screens for Android Auto using HU Reloaded?
      10-22-2019, 12:57 PM   #2807
phor
Drives: BMW X5 E70
Hi!
Have you been able to solve this issue?
I got the same one, and mixer_path is also the same.
I've spent a lot of hours trying to boost mic volume but without luck...
Originally Posted by haxx94 View Post
Hi!, I have an androd 7.1, 10.25" rooted unit for my bmw f30, I'm trying to raise up the gain of the microphone because in call and in vocal registrations the recorded volume is too low, and adding an external microphone did not resolve.
doing some research, I found that I have to edit the mixer_path.xml file located in "/system/etc/mixer_path.xml" and edit some values to raise up the mic gain, but I don't unterstand what I have to edit
can someone help me?
this is my original mixer_path.xml file:
https://drive.google.com/open?id=117...p_GOMKPaLNxbdT
      10-26-2019, 10:06 AM   #2808
Mootu
Drives: BMW F31 (2013)
Hi dear F30 community,
I've registered here because I'm a little desperate right now.
I bought a replacement head unit (display). It runs on Android and loops the signal of the normal radio. Therefore you can use Android and BMW NBT at the same time. I bought the device mainly for retrofitting Apple Car Play.
The radio is a harman hb b069.
I wanted to have the device installed in a garage first, but then I decided to install the device myself. I used this installation video: https://www.youtube.com/watch?spm=a2...&v=p6qCfTQaKN4
Well, I got down to work. Step by step everything was fine. I then finally connected everything and checked the functionality before finally reinstalling everything. It all worked. Greats
But then there were problems with the space behind the radio unit. Everything just didn't fit from the place anymore. Then I tried to move everything a bit and press it to make it fit. You could still hear the radio unit humming a bit. So there was electricity on it.
Then it suddenly stopped and everything was dead. Means the radio unit and the display simply remained silent. Nothing works anymore. So suddenly there seems to be no more electricity on it.
Now I was fast at a garage and had the fuses checked quickly. They say that everything looks fine.
Now I stand here and nothing works anymore. The air conditioner display, the cigarette lighter etc. has electricity. Just the radio unit no longer.
I also rebuilt everything and connected the original screen. That didn't help either.
Now I wanted to test whether electricity comes at all over this thick black plug or whether I broke my radio unit. Probably I have been stupid not taken the whole thing from the battery.
But I also wonder if such a radio can break so fast.
I still have the hope that it is only a plug that has come loose.
But since I'm not a garage guy nor an electronics technician, I don't know what to do and hope that you can tell me what it is or who I can turn to.
I am really desperate.
Thank you!
Translated with www.DeepL.com/Translator
      10-26-2019, 11:45 AM   #2809
Mirjam
There can also be a fuse on the radio unit, look where you connect the big black Quadlock connector. Also check that no pins are broken or bent.
      10-27-2019, 08:03 AM   #2810
Pondaire
Drives: 2013 328i
It's not the displays because the original doesn't work either.
I'd look at each and every connection. Buy a multimeter and probe every single pin that is supposed to supply power. Chances are you broke a pin, if the fuses are all good. Or you could have also shorted it and burnt something instead of the fuses.
      10-27-2019, 11:37 AM   #2811
bhe
Belgium
61
Drives: X5 G05 45e
I use a px6 in a e71...
It works but the built in mic doesn't work good and sometimes the autoconnect fails to.
      10-27-2019, 01:22 PM   #2812
tpaxadpom
Drives: 550i
Have you experimented with different DPI settings. Supposedly one can have map to fill the entire screen if DPI setting is set high enough.
BTW were you able to get it to work over USB?
      10-27-2019, 06:17 PM   #2813
machman767
machman767's Avatar
Drives: 320i M Sport+
bhe, sorry but I've just used one of your photos in my thread, Avin CarPlay, how do you get Waze to show on the nav tile with the music player, some "knowledgeable" person says it's not possible.....
      10-28-2019, 03:37 AM   #2814
Stainy
Drives: 435d M Sport Xdrive
I use Headunit Reloaded sometimes and always over USB. 160 DPI seems to be the sweet-spot for properly filling the screen, though the icons look slightly stretched.
I paid for the apk in the hope they had more aspect ratio settings in the full version. No such luck, but they don't seem quite as bad in the full version. It's probably wishful thinking because I've paid
      10-28-2019, 01:36 PM   #2815
bhe
Belgium
61
Drives: X5 G05 45e
This is over USB ... I tried wireless but didn't succeed with the new beta version, I forgot to mention but I'm paying for headunit reloaded and using the latest beta.
With the latest beta the dpi settings got easier, I played with resolution and dpi? I think this is 160 and 720p then you will get the music player and info screen and buttons to the left side.
No problem. You don't get this default, you need to change the dpi
I also paid.. and like the screen as it is now with the buttons left and extra info at the right side? The layout changed also a little bit in a recent android auto version. An other problem I have is that the sound isn't always switched when you start a sound app in android auto. I have to open the menu and go to apps or bluetooth audio so the "source" is switching from my fm radio to android auto.
      10-28-2019, 10:58 PM   #2816
tpaxadpom
Drives: 550i
How do you get 4.6 beta 5 version. I have tried the trial from xdd thread and google play store, but it is only version 4.5, so wide screen is not supported yet. Asked the question about 4.6 trial in xda thread but no answer so far. I don't mind buying it if it works.
BTW couldn't get it to work with 2 phones but worked with the third phone... USB never worked, got it going over WiFi. Instructions are confusing...
