BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 / N26 Timing Chain Failure Log
View Poll Results: Did you experience timing chain failure on your N20 engine?
Yes, my timing chain failed or required replacement. 21 14.38%
No, I have not experienced timing chain failure. 121 82.88%
I replaced my timing chain as a preventative measure. 4 2.74%
Voters: 146. You may not vote on this poll
      10-09-2019, 12:11 PM   #155
Katty29sood
Drives: BMW 320i
Hi, Planning to buy a 320i xdrive with 75000km, could you post your experiences regarding the timing chain issues near 100k? What would i need to keep in mind before purchasing.
Help will be really appreciated.
Thanks in advance.
      10-11-2019, 04:01 AM   #156
redhat
Drives: BMW F31
Model: F31 2013 320i
Build: Munich, 06.2013
Mileage: 206k km
Timing Chain Status: No problems
Oil Changes: Every 10k km since 135k, before every 30k km
Stop/Start Status: Coded off at 135k km
Additional Details: Bootmod1 at 170k km
My local workshop recommends replacing the timing chain and inspecting the oil pump next week. Personally, I did't observe the symptoms described in the forum suggesting that the repair should be done (sounds, wear or stretching of the chain). Do you think that despite the lack of symptoms, I should replace the timing chain as a preventive measure because of the high mileage?
      10-11-2019, 07:52 AM   #157
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
Thanks in advance.
Having it inspected first - pay the $150 to have it professionally looked at before buying.
Stage 2 BM3
      10-11-2019, 04:25 PM   #158
Shri2222
Shri2222's Avatar
Drives: 2013 328xi
Mine just went, I got the whine. I have 20 days of the extended 7yr 70k mile warranty left and BMW is replacing the timing chain under warranty.
No codes, just sounded like it had a supercharger.
328 xdrive
Build 10/2012
N26
58,500 miles
Mobil 1 with BMW filter Oil changed every 7k
Mods bellow since 32,000 miles when I bought mine.
start/stop disabled since 32,000 miles
2013 328 X-Drive
BMS JB4/Connect | BMW Oil Catch Can |Active Autowerke FMIC| Charge Pipe & Boost Pipe | Active Autowerke Axle-Back Exhaust | Catless downpipe | 245/40R18 Bridgestone Potenza S-04 Pole Position| H&R sport springs
      10-11-2019, 06:59 PM   #159
Solidjake
\_(ツ)_/
Solidjake's Avatar
Poland
490
Drives: '13 328i Msport 6MT
328 xdrive
Build 10/2012
N26
58,500 miles
at it failing at that mileage and having S/S disabled. Good that you just got it in time...
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      10-11-2019, 07:08 PM   #160
Troy27
Drives: Bmw f30
It would be good to know also what climate everyone that is having the failures lives in. Really cold winter's might have an effect on the plastic guides...in my opinion
      10-13-2019, 06:35 PM   #161
Shri2222
Shri2222's Avatar
Drives: 2013 328xi
Yea, I had a feeling it was going. I took it in once in February at 51,000 and they said it was good, but this time it was definitely bad.
2013 328 X-Drive
      10-13-2019, 06:37 PM   #162
Shri2222
Shri2222's Avatar
Drives: 2013 328xi
I'm in NC it's pretty hot here, but the car spent 45000 miles in NYC before I moved.
2013 328 X-Drive
Troy2736.00
      10-14-2019, 03:44 AM   #163
MilanF30
Drives: BMW F30 328i
At least you had a whining warring, it's not always a case.
Please vote if it's still available so we can have more precise results.
      10-14-2019, 03:51 AM   #164
f30nick
Drives: F30 2012 328i 6MT
75k miles getting low oil pressure warning, likely timing chain guides falling into the oil pan
Alpine White 12' F30 328i 6MT
Injen CAI | Bootmod3 Stage 2 | VRSF 5' Intercooler/Catless Downpipe | 335i M Performance Exhaust | H&R Super Sports | HRE FF01 w/Hankook Ventus Evo2 | M-Sport Retrofit
      10-14-2019, 08:46 AM   #165
floridaorange
Vs oil pump failure?
Stage 2 BM3
      10-28-2019, 02:11 AM   #166
chipguy
Drives: 12 528i
I would change the guides if the chain is not stretched. The guide could be changed by removing the valve cover. Changing the chain would also include removing the oil pan which is a lot more cost/work.
      10-28-2019, 03:49 PM   #167
jsouth
jsouth's Avatar
Drives: 2013 328i
I don't agree. You would need to remove the timing cover to replace the guides. If you're doing that, replace all of it. I don't buy the idea that the guides are at fault. I think the chain problem is breaking the guides, and catastrophic failure occurs soon after.
I see no future in just replacing guides.
sspade1499.50
      10-28-2019, 05:39 PM   #168
andino
Drives: F31 328i xdrive
I noticed the timing chain whine during my track event over the weekend. I think in my case, its an oil starvation issue but the whine is super obvious. It sounds exactly like a supercharger whine. Just something to keep in mind for those who are tracking their cars and hear the whine under heavy braking or hard left turns.
2016 328ix F31 | Bilstein B14 PSS | MPBBK | ER Catted Downpipe | REMUS Sport Exhaust | VRSF Chargepipe | G-Plus FMIC | BM3 Stage 2 | K&N Drop In Filter | KC Front Strut Bar | VAC LCA Monoball | BMS OCC | Millway Camber Plates | KMAC FCA Monoball | KC RSB
Solidjake490.00
      10-28-2019, 10:15 PM   #169
chipguy
Drives: 12 528i
Chicken or egg, it is hard to tell for sure whether the chain or the guides fail first.
Some have the dreaded whine, so this might indicate the chain. For others, absolutely no warning of any kind and my theory is the guides break first.
The N20 does not have a timing cover you can remove. Access is from the top and the bottom.
      10-29-2019, 05:39 PM   #170
sspade
sspade's Avatar
Drives: F30
2014 BMW 328i  [5.00]
You believe you can change the guides from the top only... without removing chain?
I dont see how that would be possible.
BMW 328i FBO, Bootmod3 Stage 1
      10-29-2019, 10:26 PM   #171
chipguy
Drives: 12 528i
I am sure because I just did it. This is one of the pictures from TIS
Also, included the link for the procedure.
https://www.newtis.info/tisv2/a/en/f...aft/1VncnN3x3P
      10-30-2019, 04:56 AM   #172
MilanF30
Wow, you did all this and didn't changed the chain? As i can see in the procedure, you'll need to split the chain.. I'm just curious why you did't change it, I guess the chain is the main reason guides are braking because it is stretching, and tensioner can't keep it tight anymore.
Thanks for the link for the procedure tho
sspade1499.50
      10-30-2019, 10:18 AM   #173
chipguy
Drives: 12 528i
I did not change the chain because 1. I have read the split chains are not very reliable 2. My chain is only stretched by a small amount. BTW my car has 85k miles and I changed the oil every 5k mlles.
I also installed the newer version of the tensioner.
sspade1499.50
      10-30-2019, 09:23 PM   #174
sspade
sspade's Avatar
Drives: F30
@chipguy
Very interesting, thanks for sharing.
How many of the BMW specialty tools did you actually require?
Estimated time to complete, taking your time?
      10-30-2019, 11:04 PM   #175
chipguy
Drives: 12 528i
@chipguy
The only tool I bought is the timing kit, includes the tool that hold the camshafts and crankshaft. If anyone is interested, I am more than happy to sell it.
It took me about 15 hours. But I am super slow and careful. Using a torque wrench on many of the bolts. Screwing down the valve cover bolts half a turn at a time etc. I believe this is less than 5 hours for an experienced professional mechanic. It would be an excellent time to change the spark plugs and also the belt.
sspade1499.50
      10-31-2019, 07:34 AM   #176
MilanF30
Thanks for sharing
Is it complicated to change the tensioner...I read somewhere that it's not an easy task?
