BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > How Wide Can I Go?
proTUNING Freaks
      10-02-2019, 06:38 PM   #1
ClevelandBeemer
ClevelandBeemer's Avatar
69
Drives: 2013 BMW 335i M-Sport
2015 BMW S1000R  [0.00]
2013 335i  [0.00]
2013 X5 xDrive35i  [0.00]
How Wide Can I Go?
Hi everyone!
I autocross have been in the persuit of more grip. I'm currently using a square set of 245/40/18 Bridgestone RE/71R's for autoX events. But at the power levels I'm running at I can use wider rubber in the back and more grip up front would not hurt either.
I'm not opposed to a staggered setup as that's what I daily drive with. What is the widest 18" wheel and tire combo I can get away with without rubbing or rolling fenders?
      10-03-2019, 07:59 AM   #2
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
i believe you can run an 18x9 with a 255 square.
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      10-08-2019, 03:22 PM   #3
Expert@ApexRaceParts
Expert@ApexRaceParts's Avatar
1310
Drives: M3
Indeed, with stock suspension or lowering springs, you can run 18x9" ET30 with 255/35-18 tires all around as a direct fit with no modifications required. Certain coilover setups may need front spacers, but not likely unless the car is very low.
Wider tires can also be used, but will require front negative camber, and may need rolled rear fenders as well depending on ride height and tire brand.
F30 on H&R springs with 18x9" ET30 with 255/35-18 tires all around
--Dylan
wdeerfield2116.50
      10-08-2019, 04:03 PM   #4
aps
aps's Avatar
216
Drives: '13 F30 335i
square 9.5 et35 is the limit without camber plates. but widest tire with that set up is still gonna be 255
      10-12-2019, 10:04 PM   #5
ClevelandBeemer
69
2013 335i  [0.00]
That’s what I needed to know. Thank you everyone!
