BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Catted downpipe that will pass OBDII smog test?
      10-06-2019, 02:13 PM   #1
hokiedood
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
I'm looking for catted downpipes that will pass OBDII California smog tests. Does anyone know a brand that will pass?
I also would like to know the performance gain for those downpipes. Would they also be enough to run the Bootmod3 map 2 tune on 91 octane?
      10-06-2019, 03:26 PM   #2
Logicoeur
Logicoeur's Avatar
515
Drives: F30 335i xDrive
Only two guaranteed to fall within the oem o2 delta is the Fabspeed catted downpipe, and the HJS 300 cell dp, which is what is used in the Fabspeed product. Performance gains with any of them will be around the same, until a tune is added. Then that varies even more between the PWG and EWG turbos of the N55.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
      10-07-2019, 11:10 AM   #3
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Fabspeed does not offer B58 downpipes
Check Out Our Sale Section!
Phone 725-221-5267 || website www.x-ph.com
      10-07-2019, 01:38 PM   #4
Jayf30
Drives: '18 X3 M40i Dark Graphite Cogn
I don't have an answer to your question but if changing out downpipe is an option it should take max 2 hours on your first try and 1 hour or less after that. Definitely helps to have an extra pair of hands tho.
I usually shy away from doing any work under the hood in fear that I'll break something but I'm glad I challenged myself to see the project through and now am extremely familiar and comfortable with doing the work now.
Either way, good luck!
18 X3 M40i/ Dark Graphite/ Cognac/ MP ECU Stage 2.5
      10-07-2019, 02:12 PM   #5
G.Newt
Drives: B58 6MT
CG DS-1 5" catted downpipe. It's much pricier now than when it first came out, but it's because they also use high quality cats. Lot of us running it without CELs.
https://www.ecstuning.com/b-cg-preci...e/0005ds1~cgp/
      10-07-2019, 02:18 PM   #6
Logicoeur
Logicoeur's Avatar
515
I'm guessing on the web it shows he has a b58? Can't see anything on mobile.
      10-08-2019, 06:46 PM   #7
sewhelan9
sewhelan9's Avatar
Drives: 2018 440i Gran Coupe
I went with the HJS 300 cel catted downpipe from Mike @ x-ph for this very reason, I did not want to mess with spacers, CELs, failed emissions, etc. Paired with the MHD stage 2 tune, AP intake and DINAN mid-pipe, my 440i is now a transformed car and way more fun to drive and sounds amazing, even with the stock muffler.
2018 440i Gran Coupe (F36), Glacier Silver/Black Dakota, M Performance and Track Handling Package, MHD Stage 2 and xHP Stage 3 flash tunes, Dinan Shockware and mid-pipe, HJS high-flow cat, AP Intake, RW Carbon duck bill spoiler and rear diffuser
      10-08-2019, 08:35 PM   #8
hokiedood
I'm posting to the B58 forum so it should be implied.
I don't know if the mobile version shows which forum.
      10-08-2019, 08:37 PM   #9
Logicoeur
Logicoeur's Avatar
515
Wow yeah it doesn't. I probably found this thread via New Posts
      10-08-2019, 09:15 PM   #10
hokiedood
Do you know if my 340i will pass California OBD-II smog tests with those downpipes?
      10-08-2019, 09:27 PM   #11
G.Newt
Drives: B58 6MT
Mine doesn't trigger a CEL, so I assume it meets BMW emission specs.
But, I'm not sure if the DP is CARB approved or not. I would highly recommend double checking your local emission laws.
      10-16-2019, 07:45 PM   #12
Cozmo Kraemer
Drives: 2016 340i, 2003 M3
No downpipe in CA will pass the visual inspection if they look. It could pass the sniffer test if they administer it to cars this new (I actually don't think they do). But the answer is almost always no for the visual. That being said, you could find a 'friendly' tester, or remove/reinstall stock DP for the test.
2016 - 340i Msport, MPPSK, and track handling package
2004 E46M3 - BBS RGR, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, Swaintech coated SSV1 Headers/SS catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune
