BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > engine removal ****Update****
      10-08-2019, 07:55 PM   #1
e92twin@@
e92twin@@'s Avatar
31
Drives: AW f80 M3 current SGM E92 sold
Anyone on here experience or have done a engine removal on a f30 n26 xdrive? Im working on this removing this motor because it is seized.
I want to know the easiest way, also do i drop the whole subframe with engine and transmission or can i just remove engine by itself if possible.
Any input would be appreciated thank you
****Update**** this is just a simple run through on what I did
Type of car 2013 BMW 328i xdrive N26 Automatic has 64k miles
Started the swap took me about 4 days to complete working 4-5 hours a day going slowly. (Since I have auto to put car in neutral there is a torque screw under the car next to transmission on the driver side screw it all the way up to put car in neutral this is for towing reasons)
First you disconnect the battery then I removed engine cover and intake box remove the cowl and front strut brace, I then jacked up car put it on stands and took front wheels off, the removed front bumper/ headlights/ front wheel liners/ front bumper support/ radiator support/ rad fan/ radiator and ac condenser, disconnect all necessary hoses and plugs
Next I did was remove the intake manifold, this involves removing some wire harness plugs to throttle bottle and intake tube and some vacuum lines, after manifold is removed I went and removed the starter, soon as that was removed I took the 6 bolts off the flywheel connecting to the transmission, I removed each bolt from under the car by removing the rubber tab gasket on transmission, to get to each bolt you need to turn the engine (turn it by the crank)
After that is done I took all the bolts off the transmission, then removed the front driveshaft 4 bolts and set that aside and held it up with a zip tie, then started to remove the front struts to get the axles out on both sides, also removed the bolts to the down pipe exhaust.
After that is done I put engine hoist and made sure engine is secure, then went ahead and and took the two bolts from the engine mounts out to free motor, triple check and make sure engine is free and no wires or connections are holding the engine down before lifting engine out
Got used engine from junkyard (with 60k miles) make sure itís a n26 motor if your car is a n26 can call your local dealer to confirm if you can get vins from your motor and junkyard motor
Swapped all components over from old engine to new, ac compressor, alternator, water pump ( I had to swap valve covers bc one from junkyard was cracked) check all wires and sensors see if any are broken or missing, check all wire harnesses before installing motor.
Now I just reversed this process but when installing I had to drop the subframe to get motor to clear the steering rack bc was touching
Buttoned everything up tripled checked connections, did oil change, new rad fluid, bleed system add freon check for leaks and should be good from there, go for a test drive and make sure everything is good.
Iím probably forgetting things but putting this up bc I did it in my backyard with basic tools so itís possible.
      10-08-2019, 10:22 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
https://www.newtis.info/
      10-09-2019, 07:09 PM   #3
e92twin@@
e92twin@@'s Avatar
31
Originally Posted by Billfitz View Post
thank you!
      10-15-2019, 09:07 AM   #4
Polo08816
Drives: 2014 335i M Sport
Engine removal is no small job...
      10-15-2019, 10:18 AM   #5
cfm56d7b
Good luck. This isn't the easiest job. Please ensure you have all necessary tools first. And of course stay safe.
      10-15-2019, 11:07 AM   #6
n00bkiller944
Drives: '14 328d M Sport
Post some pictures!
      10-15-2019, 11:59 PM   #7
e92twin@@
e92twin@@'s Avatar
31
Originally Posted by n00bkiller944 View Post
Post some pictures!
Uploaded some pics but I didnít take a lot
      10-16-2019, 12:00 AM   #8
e92twin@@
e92twin@@'s Avatar
31
Thank you
      10-16-2019, 12:02 AM   #9
e92twin@@
e92twin@@'s Avatar
31
Yeah I agree
      10-16-2019, 11:41 AM   #10
n00bkiller944
Nice work. How did it run after?
      10-16-2019, 12:58 PM   #11
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Do you have any more photos by any chance that you can email me?
Thanks!
Did my post help? Click "Appreciate!"
F30 328i xDrive | 475 BSM | 2A5 18" | Cold Weather | Nav Pro | Tech Pkg | Injen Intake | CW DP | VRSF IC | MR Dual Exhaust | BM3 | BC coilovers | Swift springs | Integral Audio | Retrofit: 522 & 524 EDM | 5AC | VLD | 2TB SAT | 508 | 3AG | 5DL | 6WB | 8TH
      10-19-2019, 08:18 PM   #12
e92twin@@
e92twin@@'s Avatar
31
was running good but believe im having a dme issue causing a lot of codes to pop up
      10-19-2019, 08:20 PM   #13
e92twin@@
e92twin@@'s Avatar
31
Thanks!
sorry no more pictures
      10-25-2019, 10:07 AM   #14
jkwhar
Gotcha. But thanks!
