10-12-2019, 04:53 PM | #1 |
Rep 458
Tachometer Signal Source - CPI Kit
My mechanic is trying to wire the AIC1 controller and the tachometer signal needs to be connected to pin 9 of the OBDII port according to Fuel-It
"For the rpm, that is typically pin 9 on the OBDII port. If you don’t want to use the OBDII port you’d have to find the corresponding pin at the DME in the engine bay." Does anyone know what the corresponding pin in the DME is? I don't want to use pin 9 of the OBDII port because of my BM3 wifi agent which is always plugged in.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
10-18-2019, 08:38 AM | #3 |
Rep 18
