BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Need help picking run flats plz
proTUNING Freaks
      10-13-2019, 02:04 AM   #1
straightdraw84
Drives: BMW 428i xdrive
I've got these staggered 624m's
https://www.shopbmwusa.com/PRINT/463...-21DFFF82A648=
My current tires are:
235/35ZR19
275/30ZR19
now I've found a good deal on some run flats but they're:
225/40 R19
255/35 R19
Would these be okay?
This is a for a 428i xdrive
Thanks
      10-13-2019, 05:02 PM   #2
straightdraw84
on a side not the website says:
225/35R19
245/30R19
      10-13-2019, 05:58 PM   #3
chowser51
chowser51's Avatar
Drives: 2018 BMW F33 430i xDrive
You’re current setup is at 25.47” and 25.49”.
The 225/40 and 255/35 would work and be at 26.08” and 26.02”. It will fill in the xdrive gap a little too if you’re not lowered.
The stock wheel tire sizes will be 25.2” and 24.78”.
All will work fine for xdrive.
Does your current 275 tire look too wide for your wheel?
      10-13-2019, 06:00 PM   #4
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
235/35ZR19
275/30ZR19
225/40 R19
255/35 R19
Thanks
If this is an OEM 624M wheels those tire size 225/40 and 255/35 are ok
Your original tires 275/30 for rear how did that fit on an 8.5 with 624m
      10-14-2019, 12:22 AM   #5
straightdraw84
I bought them used and they came like that, here are the pics of the front and rear wheels:
      10-14-2019, 12:53 AM   #6
Gen13 F36
Gen13 F36's Avatar
That look like a replica.. then I'm not sure what the width of those wheels. I seen 225/40 r19 on 8.5 width and 255/35 r19 on 9.5 width wheel and they are stretched a little but I can't tell on this photo if your current setup is stretched.
8.5 and 9.5 width wheel are the most common staggered setup replica wheels came with. So I would suggest getting them measure before buying 225/40 and 255/35.
      10-14-2019, 01:25 AM   #7
straightdraw84
I'm pretty sure they're oem, what kind of pic would you like?
      10-14-2019, 04:28 AM   #8
alohasurftoad
Drives: 428i gran coupe
i agree with Gen13 F36 speculation that your wheels are replicas. 19" oem 624 wheel sizes are 19x7.5 +45 and 19x8 +52. they are meant for the 2-series. it would have been impossible to install a 275/30/19 on the 8" wide rear wheel.
if your (replica?) wheels are 8.5" and 9.5", 225/40/19 and 255/35/19 are the oem staggered sizes on rwd and x-drive vehicles and a more appropriate size combination for your f-series x-drive anyhow.
the current size combo diameter is too small and is the reason your fenderwell gaps are extra large.
      10-22-2019, 11:39 PM   #9
straightdraw84
Thanks for the help guys, so the deal:
225/40 R19
255/35 R19
would work fine with my rims?
