BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N52 cam for n55 - yields solid gains
      10-16-2019, 04:04 PM   #23
AmuroRay
Drives: M235i
Originally Posted by VAF30 View Post
Its going to depend on your age or mileage on the motor as to what else you would look at .. you could just replace the exhaust cam,, but that's a lot of labor to not look at other items too.. unless your doing yourself.. in addition Id take a hard look at BPCs custom MILV solution.. for the intake side.. +1mm in intake valve opening. together could be a real solution without pulling the head and porting etc.. cool stuff coming together out there...
How are you liking the B14s?
And are you planning to run the MILVS?
FBO - Stage FP Custom tune with MHD.
      10-17-2019, 12:01 PM   #24
VAF30
VAF30's Avatar
Drives: 14' F30 335i
Would u say Labor would be more or less then a ps2 install. Just trying to ball park a price for the install + cam
So I would think if your talking about the cam plus timing chain and and components etc .. to remove and replace .. your talking 10-12 hours .. this isn't a bolt on mod you would just add .. you'd probably want another reason to be in there .. unless your chasing more power .. but if your building a motor .. I'd think you'd have to take a look .. along with other modifications to flow more and make your boost levels more efficient. BPC and ABR both have some head customizations to accomplish this as I'm sure others..
Lots of people think boost numbers are for bragging .. but if your making 525whp at 21 boost and someone else can make it at 18 .. because their ability to flow more air in and out .. then that's a much more efficient and less stressful application on components etc .. I'm sure folks who know much more will chime in .. lol ..
With any increase in flow ie more air .. it's also going to need more fuel to make it go boom .. so there's trade offs .. just again depends on your goals and why your trying to get more power.
Long answer.. hope it helps !
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
      10-17-2019, 12:10 PM   #25
VAF30
VAF30's Avatar
Still cruising on the b14s .. wish I could go a little lower in the rear .. but the ride is holding up for the price ..
Yes I'm going in. I pulled the pan to do preventative maintenance on the rod bearings .. PSA .. we found some plastic pieces of the timing chain tensioner.. ala like the n20 issues.. don't flame me n55 people .. just using as a reference.. as far as I know I'm the only one to see the issue .. and not saying the n55 has this issue. .. probably due to a stretched chain slapping .. as in the n55 platform bmw used a pretty thin chain for engineering reasons and stock or mild tune I would think most would never see the issue. That said .. I'd keep an eye on it.
So since I was now going into a TC and components.. I decided to go ahead with some of the other upgrades too .. bad part is I won't have a baseline since the bigboost kit is going on at same time. .. but would like to see if I gained any higher hp at boost levels per the average out there .. anyway .. nothing wrong with a little more lift and a little more duration! MHO ..
How's yours going ?
      10-17-2019, 01:13 PM   #26
AmuroRay
Drives: M235i
How's yours going ?
Just got a custom tune from Bob @ Stage FP (used to be the tuner BPC) and Iím itching to drive the car - SO much power, I canít imagine adding more than this!
I have a VC leak, so Iíll be installing the MILVs soon here too.
Phyrexia480.00
harkes806.00
      10-18-2019, 03:58 AM   #27
harkes
harkes's Avatar
China
806
Drives: M135i, NSX and AE86
Just got a custom tune from Bob @ Stage FP (used to be the tuner BPC) and I’m itching to drive the car - SO much power, I can’t imagine adding more than this!
I have a VC leak, so I’ll be installing the MILVs soon here too.
Has anyone seen N55 logs with/without MILVs yet? I am really excited
PLEASE document the before/after best you can. No dyno needed just same road, same conditions, 4th gear pull, then VirtualDyno can do the magic Hopefully we will see lower WGDC with same load.
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      02-04-2020, 01:23 PM   #28
e38740imd
Drives: 2016 640i
any updates?
      02-04-2020, 05:52 PM   #29
AmuroRay
Drives: M235i
Originally Posted by e38740imd View Post
any updates?
Ran out of fuel - I need a fuel pump.
      02-04-2020, 09:09 PM   #30
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
any updates?
When you changed the cam did you refresh the valvetronic?
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      02-05-2020, 12:15 AM   #31
AmuroRay
Drives: M235i
No, you donít need to do that.
      05-28-2020, 08:35 AM   #32
AmuroRay
Drives: M235i
Originally Posted by BMW DIY Guy View Post
I am running the VSRF cooler now, as it was the largest I could possibly fit into that space.
Race or Competition? And how has the cooling been? Livability?
      06-01-2020, 10:48 AM   #33
Skrrtt335
Drives: 2015 335
+1 good info
